DMVPN with multi HUB
miskoolak
Dear all
I have seven hub with several routers at remotes.
now each router at remote has it hub router. but i to establish other tunnel to other hub but with priority issue for redundancy.
any document or sample?
regards to all
paolo bevilacqua
Yes, the examples are in the dmvpn design guide and white papers.
Note, you don't necessarily need to use another tunnel. With proper configuration you can use a single p-to-mp tunnel and multiple hubs within it.
hope this helps, please rate post if it does!
blubericisco
Take a look at http://www.cisco.com/en/US/tech/tk583/tk372/technologies_white_paper09186a008018983e.shtml at the "Dual Hub - Dual DMVPN Layout" section. That should get you going.
