DNS question
ankitohc
I have a question regarding the DNS If I have website with domain abc.com (Example), also we have internal windows domain controller DC-01 where we have our internal DNS server. I can add the A record in internal DNS abc.com pointing to public IP so my internal users can access the website like example shown here
but here is the problem when our internal users are opening website with abc.com it won't work and when they add www.abc.com
it worked fine so what could be the issue? It looks like DNS issue for sure If i create one more A record pointing abc.com to public IP so now there will be two records one is with www and one is without www so what will happen with our internal users if they have host with abc joined domain where will the request go first if they
ping
website or join new machine in the company. Will it go to local DNS or public?
@ankitohc,
Internal DNS resolution, including domain join requests, will use the DNS records in your internal DNS server. External access to the public website "abc.com" remains unaffected. Creating an internal DNS record for "abc.com" ensure internal users can access the website without the "www" prefix while preserving domain join functionality.
Best regards
5 Replies 5
M02@rt37
Hello @ankitohc,
When a domain-joined machine attempts to resolve abc.com, it first checks with the local DNS server, which in your case is your internal Windows DNS server (DC-01). If there's a matching DNS record (A record) for abc.com in your internal DNS pointing to a local IP address, it will use that.
However, if there's no record for abc.com in your internal DNS, or if the record points to a public IP address, the request will go to the public DNS servers on the internet, which resolve abc.com to the public IP address associated with the domain.
So, if you want your internal users to access abc.com without the "www" prefix, create an A record in your internal DNS for abc.com pointing to the public IP address of your website.
Also, leave the A record for www.abc.com pointing to the public IP address. This will continue to work for users who type "www.abc.com."
--Internal users will be able to access the website with or without the "www" prefix. If they
ping
abc.com or join a new machine to the domain, the internal DNS server will resolve the request based on the DNS records you've configured internally.
Best regards
Thank you for the detailed explanation, If I create a DNS entry without www If I join any machine in the domain future will it impact anything since I will type abc.com to join the domain and the request will go to internal DNS which currently maps with public IP address
@ankitohc,
Best regards
Thank you. I really appreciate your quick answer.
Joseph W. Doherty
Firstly, generally I believe it's a somewhat unusual to be creating any DNS records for external Internet hosts.
An internal DNS server would be where you define DNS records for your internal resources.  Such a server should pass a match failure to the public DNS servers for resolution.  (If a public DNS server resolved the DNS request, your internal DNS server normally would cache the result for some amount of time.)
Regarding not providing the whole FQDN, you "abc.com" example, I recall (?) there's a way to define a presumed "default", such as commonly used "www", but that's up to the administrator for a particular DNS domain.
I mention the foregoing because you're preempting DNS management of DNS resources not yours.  Usually the only time you might do this is when you're trying to black list some external sites from your network.  (Which can be a big time sink.  If that's your goal you might want to look into commercial products that continually update various black lists.)
