do you need mp-bgp to route between vrf's
carl_townshend
Hi All
do you need mp-bgp to route between vrf's? or could you use eigrp etc?
6 Replies 6
Julio E. Moisa
It is not required If you are not going to use it over MPLS. VRF is significant locally.
For example if your topology is like:
R1 (VRF) ----- R2 ---- R3
You can use EIGRP on the 3 routers but you must run EIGRP over the VRF.
router eigrp TEST
address-family ip4v4 vrf MY-VRF autonomous-system 100
It can be made over EIGRP named instance only.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
can you give me an example of routing between them on 1 router, route leaking ?
Sure, for example
R1 (VRF) f0/0 ----- fa0/0 R2
R1
ip vrf A
rd 1:1
(router-target is not required if you will not use MPLS)
interface loopback0
ip vrf forwarding A
ip address 1.1.1.1 255.255.255.255
interfarce fa0/0
ip vrf forwarding A
ip address 10.12.0.1 255.255.255.0
no shutdown
router eigrp MY-EIGRP
address-family ipv4 vrf A autonomous-system 100
network 10.12.0.1 0.0.0.0
network 1.1.1.1 0.0.0.0
R2
interface loopback0
ip address 2.2.2.2 255.255.255.255
interfarce fa0/0
ip address 10.12.0.2 255.255.255.0
no shutdown
router eigrp 100
network 10.12.0.2  0.0.0.0
network 2.2.2.2 0.0.0.0
no auto-summary
 Or
address-family ipv4 unicast autonomous-system 100
no auto-summary
Hope it is useful
im talking about routing between 2 different vrf's, yours looks like the same?
If it is for different VRF you could not intercommunicate them directly because they have different instance, different routing tables. You can just leak the routes using import/export maps or trying with the route-maps:
ip vrf A
rd 1:1
route-target export 1:1
route-target import 1:1
route-target import 2:2
ip vrf B
rd 2:2
route-target export 2:2
i think you will still need to redistribute between the protocols even with the import/export maps?
I hear you can only do this with mp-bgp?
