Do you think the two ip address can be used for connection?
wfqk
Level 5
Level 5
Hi, I notice there are two ip address which are connected with in two separate devices. I am not sure it can work. Any one explain it? Thank you
One ip address is 10.10.10.196/31, and another is 10.10.10.197/31
I guess the network ip already become host ip address
Philip D'Ath
As long as you are running modern Cisco code that will be fine.  /31's are used to reduce IP wastage.
Thank you for your reply. How about broadcast address? Can you explain "modern CIsco code" used here?
Since /31 is used for point to point links you only need 2 IPs an so there is no need for broadcast address. "Modern Cisco codes" means newer IOS version.
Thank you Reza
What version is new version? Using the following version is also Ok
Router#sh ver
Cisco IOS Software, 3600 Software (C3640-TELCO-M), Version 12.3(11)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by Cisco Systems, Inc.
Compiled Sat 18-Sep-04 14:32 by eaarmas
ROM: ROMMON Emulation Microcode
ROM: 3600 Software (C3640-TELCO-M), Version 12.3(11)T, RELEASE SOFTWARE (fc2)
