Dynamic bandwidth selection for PPPoE over Ethernet/VLAN
hiepnguyenho
Hello all, hope you are doing great.
I'm planning to deploy PPPoE Server (Cisco Router 7609) for a ISP. This ISP will provide Internet connection for customer over Ethernet.
I have to provide a solution to assign bandwidth to each customer by RADIUS and I find some clues that Dynamic Bandwidth Selection (DBS) should be the answer. Unfortunately, DBS only support PPPoA or PPPoE over ATM.
If you have any experience with equivalent function, please help me. Thank you very much.
Hiep Nguyen.
Stephen Teusch
Hiep Nguyen,
I was looking into this too.
The only thing I could think of so far would be to use radius to assign the IP, and build a large policy map so the bandwidth could be changed by choosing an IP from a given level of service.
Did you come up with a solution?
Stephen Teusch
Hiep,
I think I have figured this out.  Here is the test config on my PPPoE server:
int lo1
  ip address 172.25.25.25 255.255.255.255
ip radius source-interface Loopback1
aaa new-model
radius-server host 172.16.1.55 auth-port 1812 acct-port 1813 key cisco$$$
aaa group server radius RADIUS-ACT
 server 172.16.1.55 auth-port 1812 acct-port 1813
aaa authentication login default group RADIUS-ACT local
aaa authorization exec default group RADIUS-ACT local
aaa accounting exec default start-stop group RADIUS-ACT
aaa accounting delay-start
aaa authentication ppp default if-needed group RADIUS-ACT local
aaa authorization network default group RADIUS-ACT local
aaa accounting network default start-stop group RADIUS-ACT
aaa accounting update periodic 5
bba-group pppoe global
 virtual-template 1
interface fa0/1
 pppoe enable group global
 ip address 172.30.0.1 255.255.0.0
 no shut
interface Virtual-Template1
 mtu 1492
 ip unnumbered FastEthernet0/1
 peer default ip address pool GLOBALPOOL
 ppp authentication chap
ip local pool GLOBALPOOL 172.30.0.2 172.30.127.255
policy-map POLICE-128K
 class class-default
    police 128000
policy-map POLICE-512K
 class class-default
    police 512000
Here are the attributes on the radius server, for a group the PPPoE customer belonged to:
Service-Type = Framed
Framed-Protocol = PPP
cisco-avpair="ip:sub-policy-In=POLICE-128K"
cisco-avpair+="ip:sub-policy-Out=POLICE-512K"
Here is the show policy-map on the virtual-access interface the client connected on:
sho policy-map int virtual-a 3
 Virtual-Access3
  Service-policy input: POLICE-128K
    Class-map: class-default (match-any)
      1000 packets, 1402000 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: any
      police:
          cir 128000 bps, bc 4000 bytes
        conformed 799 packets, 1120198 bytes; actions:
          transmit
        exceeded 201 packets, 281802 bytes; actions:
          drop
        conformed 0 bps, exceed 0 bps
  Service-policy output: POLICE-512K
      911 packets, 1137746 bytes
      Match: any
      police:
          cir 512000 bps, bc 16000 bytes
        conformed 799 packets, 1136178 bytes; actions:
          transmit
        exceeded 0 packets, 0 bytes; actions:
          drop
I was able to generate enough traffic with ping to meet the exceed action in and have it drop packets.
Hi Steven,
I got some troubles with your lab about defining ip:sub-policy-In on DaloRarius, could you please help?
Pedro,
It displays a SQL error.  This means that daloRadius is able to parse the request but your SQL server is not reading the SQL statement is creating for backend storage.  There is probably some versioning or SQL setting in dalo so the correct or supported SQL statements are used.  I cannot help you find it but I did a build guide for when I created my daloRadius server:
http://ephemeralportal.blogspot.jp/2014_07_01_archive.html
