Does 1841 support IPSec vpn ?
sivakondalarao
I have 1841 router. show version details are:
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.3(11)T3, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 25-Jan-05 14:20 by pwade
ROM: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
SCB-EURO uptime is 1 week, 5 days, 17 hours, 46 minutes
System restarted at 18:53:24 UTC Sun Aug 13 2006
System image file is "flash:c1841-ipbase-mz.123-11.T3.bin"
Cisco 1841 (revision 5.0) with 113664K/17408K bytes of memory.
Processor board ID FHK090910YH
2 FastEthernet interfaces
2 Serial(sync/async) interfaces
1 ISDN Basic Rate interface
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31744K bytes of ATA CompactFlash (Read/Write)
Does it support IPSec VPN?
If not what are the upgradations I have to do?
I know following options pleas correct me:
1 Installing VPN module in AIM slot and
2 Upgrading IOS to IPSec supported version.
Required your suggestions.
SKRAO
vijayasankar
Level 4
Level 4
Hi Siva,
The current IP base package that you have doesn't support IPSec.
You need to have a Advance security package for that.
Check out this link to understand the IOS packaging details and the feature set hierarchy
http://www.cisco.com/en/US/products/sw/iosswrel/ps5460/index.html
To understand more on IOS packaging, visit this QA section
http://www.cisco.com/en/US/products/sw/iosswrel/ps5460/products_qanda_item09186a00801af2c6.shtml
Use the feature navigator at the following URL, using which you can find out features supported based on platforms, the current ios image that you have etc.
A Very usefull tool, to understand what is currently supported with your devices/ios and how you can plan for upgradation.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
AIM is optional. For additional throughput and other benefits your can opt for it.
-VJ
