access-list
aperez2004
I have a problem with access-list. I am have three different networks, one is (assuming IP, just for protection) 1.1.1.0, 1.1.2.0 and 1.1.3.0. So I have three routers a each network, R1, R2 and R3. I wan network 1.1.1.0 talk to 1.1.2.0 but should NOT communicate with 1.1.3.0. Also 1.1.3.0 can talk to 1.1.2.0 but not to 1.1.1.0. So in R1 I configured the access-list the following way,
access-list 100 deny ip 1.1.1.0 0.0.0.252 1.1.3.0 0.0.0.252
access-list 100 permit ip any any
Then in interface fa0/0 I typed, ip access-group 100 in. I also do the same thing with R3 and I changed the IP address. It works fine but I am not happy with the command, permit any any. Is there another way so that this should work? I tried replacing the permit ip any any with permit ip 1.1.1.0 0.0.0.252 1.1.2.0 0.0.0.252 but does NOT work.
Any comments or suggestions are welcome.
You can do this with one statement like the one noted below. The implicit deny rule will drop everything else.
R1:
access-list 100 permit ip 1.1.1.0 0.0.0.255 1.1.2.0 0.0.0.255
int f0/0
HTH,
Sundar
11 Replies 11
R1:
int f0/0
HTH,
Sundar
I must be doing something wrong because I tried that and it block all the networks.
I just tried it and it doesn't work.
Are these routers on the same ethernet segment?
Or tell us how are they are connected.
they are connected on the serial port on a T1 circuit.
That should work.
What's the source and destination IP address of the pings? Are you using a 24-bit mask for these networks?
Looking at your previous posting why do you have the wild card mask set to 0.0.0.252?
Do you mean to include networks 1.1.1.0/24 - 1.1.3.0/24. If that's what you want then the WC you need to use is 0.0.252.255.
Sundar
"Do you mean to include networks 1.1.1.0/24 - 1.1.3.0/24. If that's what you want then the WC you need to use is 0.0.252.255."
Perhaps you mean, 0.0.3.255 ?
Oops, am typing too quickly. thanks for correcting that Edison :-)
That should work.
It works the way you said it, 0.255. So what I am trying to do is to access the routers from any network but restrict the networks so they can't communicate (1.1.1.0 can't to 1.1.3.0). That's why I had 252 because the router ip is .253
