04-02-2006 10:48 PM - edited 03-03-2019 12:16 PM
hi,
what i know is 7204VXR will not support supervisor engines. It will support only NPE.
I am using only one chassis, so I want provide redundancy on 7204VXR. Does it support?
skrao
Solved! Go to Solution.
04-02-2006 10:54 PM
The only redundancy you get with a 7204VXR is redundant power supplies - you cannot install redundant NPEs/
Hope that helps - pls rate the post if it does.
Paresh
04-02-2006 10:54 PM
Paresh
