Does anyone setup the 3G on 819 router?
Emmanuel Valdez
Level 3
Level 3
Hello everybody,
I acquired an 819 router with a integrated HSPA+R7 modem, does anyone setup the 3G internet option with this modem? My 3G ISP is Telcel.
Best regards.
14 Replies 14
Emmanuel Valdez
Level 3
Level 3
I setup the 3G connection succesfully, I explain the process maybe it will be useful for somebody in the future:
I have a Cisco C819HG+7-K9 with a MC8705 HSPA+R7 modem, my ISP is Telcel, this is a new model of modem and it only support slip encapsulation, the process to setup the 3G connection is the following:
1.- Create a gsm profile:
          C819HG_3G#cellular 0 gsm profile create 1 internet.itelcel.com pap webgprs webgprs2002
where:
APN is internet.itelcel.com
username is webgprs
password is webgprs2002
The profile 1 is the default for the sim under slot 0
2.- Like this is a new model of modem we have to use the new chat script:
           C819HG_3G(config)#chat-script gsm "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
3.- Config the celullar interface:
           C819HG_3G(config)#interface cellular 0
           C819HG_3G(config-if)#ip address negotiated
           C819HG_3G(config-if)#ip nat outside
           C819HG_3G(config-if)#ip virtual-reassembly in
           C819HG_3G(config-if)#encapsulation slip
           C819HG_3G(config-if)# dialer in-band
           C819HG_3G(config-if)#dialer idle-timeout 0
           C819HG_3G(config-if)#dialer string gsm
           C819HG_3G(config-if)#dialer-group 1
           C819HG_3G(config-if)#async mode interactive
4.- Configure the LAN interface, in my case the SVI 1
           C819HG_3G(config)#interface Vlan1
           C819HG_3G(config-if)#ip address 192.168.150.1 255.255.255.0
           C819HG_3G(config-if)#ip nat inside
5.- Configure the modem line, for model 819 the line is the number 3
           C819HG_3G(config)#line 3
           C819HG_3G(config-line)#exec-timeout 0 0
           C819HG_3G(config-line)#password cisco
            C819HG_3G(config-line)#script dialer gsm
           C819HG_3G(config-line)#login
           C819HG_3G(config-line)#modem InOut
           C819HG_3G(config-line)#no exec
           C819HG_3G(config-line)#transport input all
6.- Make a default route pointing the Cellular interface
           C819HG_3G(config)#ip route 0.0.0.0 0.0.0.0 Cellular0
7.- Setup NAT, in my case I used a route-map
          C819HG_3G(config)#route-map Internet permit 10
          C819HG_3G(config-route-map)#match ip address 101
          C819HG_3G(config)#access-list 101 permit ip 192.168.150.0 0.0.0.255 any
          C819HG_3G(config)#ip nat inside source route-map Internet interface Cellular0 overload
8.- You have to generate some Internet traffic, if you omit this step the cellular interface will not obtain a public IP address from the ISP, you can check that your profile come up with "show cellular 0 profile"
C819HG_3G#sh cellular 0 profile
Profile 1 = ACTIVE*
PDP Type = IPv4
PDP address = X.X.X.X
Access Point Name (APN) = internet.itelcel.com
Authentication = PAP
Username: webgprs
Password: webgprs2002
        Primary DNS address = Y.Y.Y.Y
        Secondary DNS address = Z.Z.Z.Z
* - Default profile
Configured default profile for active SIM 0 is profile 1.
You can use a "debug chat" on the router to view if you have a problem to establish the connection.
I hope this information will useful.
Regards.
hello
thanks, was helpful the configuration my 3G ISP is Telcel to.
I think this router can send messages?
anyone know the configuration for send and receive SMS or mesaages??
thank you bro....
Hi Ivan,
You have to use the cli command:
cellular 0 gsm sms send 5523457690 "Text of the message"
Where: 5523457690 is the desired destination number.
Regards.
perfect  ef-molina
many thanks
erdinc
Router#cellular 0 gsm profile create 1 MGPS pap null null
% Invalid input detected at '^' marker.
How can solve this ?
First you need to be in config mode.
#configure terminal
Then you will be able to configure the interface.
Emmanuel Valdez
Level 3
Level 3
Maybe you don´t have a modem installed on your router, place a show version and show diag,
Regards.
erdinc
Rout#show diag
Slot 0:
        C819G Mother board Port adapter, 10 ports
        Port adapter is analyzed
        Port adapter insertion time 00:03:11 ago
        Hardware Crypto Engine Details:
        The CHIP id is 0x20000
        The SEC revision no is 0x1
        EEPROM contents at hardware discovery:
        Hardware Revision        : 6.0
        PCB Serial Number        : FOC17132G06
        Processor type           : DD
        Part Number              : 73-14148-02
        Board Revision           : A0
        Top Assy. Part Number    : 800-39743-01
        Fab Version              : 06
        Product (FRU) Number     : C819G-4G-G-K9
        Version Identifier       : V01
        Chassis Serial Number    : FCZ1725937P
        MAC Address block size   : 32
        Chassis MAC Address      : 20bb.c040.3ff4
        CLEI Code                : CMMJ600ARA
        Deviation Number         : 135672
        RMA Number               : 0-0-0-0
        RMA Test History         : 00
        RMA History             : 00
        Asset Identifier
        EEPROM contents (hex):4
          0x00: 04 FF 40 06 F3 41 06 0 C1 8B 46 4F 43 31 37 31
  0x10: 33 32 47 30 36 09 DD 8249 37 44 02 42 41 30 C0
          0x20: 46 03 20 00 9B 3F 01 02 06 CB 8D 43 38 31 39 47
          0x30: 2D 34 47 2D 47 2D 4B 39 89 56 30 31 20 C2 8B 46
          0x40: 43 5A 31 37 32 35 39 33 37 50 43 00 20 C3 06 20
          0x50: BB C0 40 3F F4 C6 8A 43 4D 4D 4A 36 30 30 41 52
          0x60: 41 88 00 02 11 F8 81 00 00 00 00 03 00 04 00 D9
          0x70: 03 40 C1 C2 CC 86 30 30 30 30 30 30 F3 00 30 40
          0x80: A2 55 41 00 14 42 00 00 F8 00 24 03 E8 1E 78 08
          0x90: 70 1F 40 0C F8 1F A4 11 75 1F B8 15 E0 1F 80 1A
          0xA0: 2C 1E DC 1E A5 1E AA 22 F6 1E C8 27 10 1E AA FF
          0xB0: FF FF FF FF F FF FF FF FF FF FF FF FF FF FFFF
          0xC0: FF FF FF FF FFFF FF FF FF FF FF FF FF FF FF F
          0xD0: FF FF FF FF FF F FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF F   0xF0: FF FF FF FF FF FF FFFF F
Embedded Service Enine wlan-ap 0 :
   Total patform memory : 1048576K bytes
                                            Total 2nd core memory : 31072K bytes
   Start of pysical address for 2nd core : 018000000
  2nd core configured enabled
  L2 cache shared between 1st and 2nd cores.
Rout#show version
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.2(4)M3, RELEA
SE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 26-Feb-13 12:39 by prod_rel_team
ROM: System Bootstrap, Version 15.2(2r)T, RELEASE SOFTWARE (fc1)
Rout uptime is 4 minutes
System image file is "flash:c800-universalk9-mz.SPA.152-4.M3.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. law governing Cisco cryptographic roducts may be found at:
htp://www.cisco.com/wwl/export/cypto/tool/stqrg.html
If you require further assistane please contact us by sending mail to
          co.com.
Cisco C819G-4G-G-K9 (evision 6.0) with 883788K/33715 bytes of memory.
Process board ID FCZ1725937P
4 FatEthernet interfaces
1 Gigaerface
1 Serial(sync/async interface
  2 terminal lines
1 Virtual Private(VPN) Module
1 Cellular interface
1 cisco Embedded AP (s)
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
999936K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C819G-4G-G-K9         FCZ1725937P
License Information for 'c800'
    License Level: adipservices   Type: Permanent
          ret license Level: advipservices
      Configuration register is 0x210
Emmanuel Valdez
Level 3
Level 3
Can you post a "show cellular slot/wic/port radio"
For example show cellular 0/0/0 radio
I saw that you router support 4G LTE but in your show diag doesn´t appear the modem.
Regards.
erdinc
Rout#show cellular 0 radio
Radio power mode = ON
Current RSSI(RSCP) = -67 dBm
LTE Technology Preference = AUTO
LTE Technology Selected = UMTS
Rout#show cellular 0 all
Hardware Information
Modem Firmware Version = SWI9200X_03.05.19.04
Modem Firmware built = 2012/09/17 17:57:14
Hardware Version = 10
International Mobile Subscriber Identity (IMSI) = 28615210605028
International Mobile Equipment Identity (IMEI) = 359470040049043
Integrated Circuit Card ID (ICCID) = 8990010907260050289
Mobile Subscriber International Subscriber
IDentity Number (MSISDN) = SWI9200X_03.
Profile Information
Profile password Encryption level: 7
Profile 1 = INACTIVE*
PDP Type = IPv4
Authentication = None
Username:
Password: 09
* - Default profile
Data Connecti=========================
Data bytes, Received = 0 bytes
-Profile 1, Pact Session Status = INACTIVE
        Inactivity Reason = Unknown
Profile 2, Packet Session Sttus = INACTIVE
-      InactivityReason = Unknown
Profile 3 Packet Session Status = INACTIE
        Inactivity ReasoProf 4, Packet Session Status = INATIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Sesion Status = INACTIVE
        Inctivity Reason = Unknown
Pr Session Status = INACTIVE
Profile 13, Packet Session Sttus = INACTIVE
Profile 1, Packet Session Status = INACTIVE
Profie 15, Packet Session Status = IACTIVE
        Inactivity Reason  Unknown
Profile 16, Packe Session Status = INACTIVE
on = Unknown
Network Information
Curret Service Status = Normal
urrent Service = Packet switche
      aming Status = Home
Netwo Selection Mode = Automatic
Code (MCC) = 286
-Mobile Nework Code (MNC) = 1
Packet switch domain(P) state = Attached
Registtion(EMM) state = Registered
        formation
Current RSSI(RSCP) = -68 dBm
--MLTE Ty Preference = AUTO
LTE Tehnology Selected = UMTS
Modm Security Information
Cardtion (CHV1) = Disabled
SIMStatus = OK
SIM User Operaion Required = None
Numberof CHV1 Retries remaining = 3
Error Information
Ths command is not supported on 4 modems.
ModemCrashdump Information
Modem crashdump loging: off
Emmanuel Valdez
Level 3
Level 3
Try with these:
Router# cellular 0 lte profile create 1 MGPS ipv4
Regards.
erdinc
Rout#cellular 0 lte profile create 1 MGPS ipv4
Profile 1 already exists. Do you want to overwrite? [confirm]y
Profile 1 will be overwritten with the following values:
PDP type = IPv4
APN = MGPS
Are you sure? [confirm]y
Profile 1 written to modem
