Does Cisco make a 3G Card for AT&T
Patrick McHenry
Level 4
Level 4
The 3G card that I've been deploying for some remote users, using the 881 that live in remote areas have an esn number for Verizon. Can I order a card that would be used with AT&T?
Thanks, Pat
Leo Laohoo
PCEX-3G-HSPA-US
Cisco 3G HSPA/UMTS/EDGE/GPRS Modem-AT&T Network Only
Cisco 880G Series 3G Wireless Integrated Services Router (Table 4)
Thanks -
Do you happen to know if there is a 4G option for the 881?
Can the usb interface on the front of the router be used as a routed port? Am I crazy?
By the way - is there any tweaking I can do to the cellular interface to make the Antenna that hangs off the card have a stronger signal? Any bandwidth settings? Or, is there a stronger antenna I could use? The 3G solution is hovering on not being usable in some situations. I wondering if there are things I can do to make it perform as well as it possibly can.
Thanks, Pat.
