Does Cisco Switch 3850 and 2960X Switches support Radius MS-CHAP-V2
ringongoh
Hi all,
Does Cisco Switch 3850 and 2960X Switches support  Radius MS-CHAP-V2?
If Yes, can i get it configure on both switches and windows server 2012 r2?
hope someone can provide an advise on this.
Many thanks,
Ringo Ngoh
kandariaditya65
Hello Ringo,
             I have gone through your question. Yes, the switches 3850 and 2960X supports Radius and MS-CHAP-V2. Radius method uses an external authentication server while Local EAP method uses local user database or LDAP  to authenticate clients.Local EAP method supports MS-CHAP V2, but only if LDAP server is setup to return a cleartext password.
Yes, you can also configure a windows server 2012 as Radius server. Windows server has a network policy service using which it can also be configured as radius server.
Aditya kandari
Spooster IT Services
