Does configuring two VLANs on Cisco 871 router divides the bandwidth (to Internet) into half?
md_ali_525
I use the cisco 871 router as a firewall to my home-office. I have configured two vlans for each seperate port.
That is, FE0 configured as VLAN 10  ----> connected to Layer 2 Switch
            FE1 configured as VLAN 20 ----> connected to another Cisco Layer 2 Switch
            FE2 not in use
            FE3 not in use
and       FE4 is connected to WAN.
I got 100Mbps speed from the ISP, but I can see that I only get 50mbps even connected to VLAN 10 or VLAN 20.
Please help me out
Thanks in advance,
MA
23 Replies 23
cadet alain
No it doesn't, but if you get traffic from vlan 2 and you test from vlan 1 then you won't get the same result of course.
The bandwidth is used by 2 people from one vlan or 2 people from 2 vlans , it's the same for the WAN interface.
How do you know you get 100 Mbps ?
Alain
Hello Alain,
Thank you very much for your reply,
I have connected directly to the ISP instead of 871 router. I got 100mbps. but when I connected this router  and checked the speed,  i get only 50mbps.
Please help.
MA
Here is the running configuration:
Cisco871#sh run
Building configuration...
Current configuration : 2591 bytes
version 12.4
no service pad
service password-encryption
hostname cisco871
boot-start-marker
boot-end-marker
enable secret ********
enable password ******
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1 192.168.0.99
ip dhcp excluded-address 192.168.0.254
ip dhcp pool LAN-DHCP-POOL
   import all
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   dns-server    xx.xx.xx.xx                # DNS IP
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
vpdn enable
vpdn-group 1
archive
log config
  hidekeys
interface FastEthernet0
switchport access vlan 10
interface FastEthernet1
switchport access vlan 30
shutdown
interface FastEthernet2
interface FastEthernet3
switchport access vlan 20
interface FastEthernet4
ip address xx.xx.xx.xx  255.255.255.240   #WAN IP
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered FastEthernet4
peer default ip address pool defaultpool
ppp authentication chap ms-chap
interface Vlan1
no ip address
ip nat inside
shutdown
interface Vlan10
description Inside
ip address 192.168.0.1 255.255.255.0
ip nat inside
interface Vlan20
description Lab-SW-02
ip nat inside
interface Vlan100
no ip address
interface Vlan200
no ip address
interface Vlan30
description IP- Phone
ip address 192.168.2.2 255.255.255.0
ip nat inside
shutdown
ip local pool defaultpool 192.168.100.1 192.168.100.254
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 xx.xx.xx.xx      #WAN IP
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 permit 192.168.0.0 0.0.255.255
control-plane
line con 0
exec-timeout 0 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
password ******
login
scheduler max-task-time 5000
end
I believe that your interface Fa0/4 speed is 100 Mbps but you will get real speed as per your link bandwidth.
Your ISP device will connect to that port at 100 Mbps only but speed depends upon the link you have purchased.
If you have purchased 2 Mbps link and its terminating on your Fa0/4 via ISP device, it will show that Fa0/4 speed is 100Mbps but you get upto 2Mbps only. It will connect at 100Mbps but link speed will be 2Mbps.
Also creating VLAN never divides the speed into two half, if one user in any VLAN is using some bandwidth, other user will get the rest of the bandwidth. You speed / bandwidth is shared among the number of users currently access it.
Hi Sakun Sharma,
I have purchased 100 Mbps. And also I have tested by configuring my laptop instead of router with public IP given by ISP, I got 100 Mbps. But, if I connect via this router, then I get only 50 Mbps.
I have copied my router configuration in the previous reply above, please check it and let me know if there exist some configuration which is dividing the bandwidth?
Thanks alot,
Best regards,
MA
Hi Ali,
Thanks for your reply and clearification on bandwidth purchased.
There isn't anything in your config due to which bandwidth should be divided between VLANs.
You can try testing the bandwidth from VLAN 10 after shutting down all other VLAN interfaces for test purpose, also same test for other VLAN's. If you are getting complete 100 Mbps on individual VLAN after shutting down other VLANs interfaces, that means there is some device which is using bandwidth. Because its not possible that router itself divides the bandwidth between VLAN's.
Are you getting exactly 50 Mbps on both the VLANs, when tested one by one?????
Hi Sakun Sharma,
Thanks for your reply,
yes, I am getting 50 Mbps on vlan10, when tested by shutting down all other vlans except vlan10.
I have not tested by shutting vlan10 and connecting to vlan20. I will test this tomorrow morning.
There are many devices connected in vlan 10. But, I have only two devices connected in vlan20. Hence it was easy for me to shutdown vlan20 and test the vlan10.
I will reply you as soon as I test by shutting down vlan 10.
Thanks once again,
MA
Hi Sharma,
I am getting 50 Mbps even if I tested one by one VLAN.
First, I have shutdown the vlan 20 and tested the bandwidth by connecting to vlan 10. I got the same 50 Mbps
Second, I have shutdown the vlan 10 and tested the bandwidth by connecting to vlan 20. I got the same 50 Mbps.
But I have been allocated 100 Mbps from the ISP. where is the half bandwidth???? which device is using this half bandwidth. I'm totally confused...:(
Please help.
Thank you,
MA
Exactly 50 Mbps on both is really confusing. Meanwhile, I see and serach more about this in your config, can you test bandwidth on both VLAN's simultaneously. Run the test simultaneously on two machine in different VLANs.
Also can you directly attach your laptop to internet interface and test again.
I have tested bandwidth on both the VLANs simultaneosly and got 40-45 Mbps. Also, I have tested directly connecting to the WAN interface and got 95 Mbps.
Please suggest... Any help willl be really appreciated...
MA
Working on your config, but nothing such there.
You can try setting speed and duplex from auto to manual configuration on Fe0, Fe2, Fe3 to Full duplex 100 Mbps.
Sometimes duplex and speed autonegotiation creates problem.
Also can you post the output for show interface command for fe0, fe2, fe3, fe4, virutal-template1, and show ip int brief command output.
Message was edited by: Sakun Sharma
Thank you very much for your reply and also sorry for late...
Here is the output of show interface and show ip int br:
Cisco871#sh interfaces fastEthernet 0
FastEthernet0 is up, line protocol is up
  Hardware is Fast Ethernet, address is 0022.55e1.c144 (bia 0022.55e1.c144)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s
  Last input 00:00:23, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 9000 bits/sec, 7 packets/sec
  5 minute output rate 58000 bits/sec, 22 packets/sec
     66711853 packets input, 4102443883 bytes, 0 no buffer
     Received 3054569 broadcasts, 0 runts, 0 giants, 0 throttles
     66940136 packets output, 1626132099 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 lost carrier, 0 no carrier
Cisco871#sh interfaces fastEthernet 1
FastEthernet1 is administratively down, line protocol is down
  Hardware is Fast Ethernet, address is 0022.55e1.c145 (bia 0022.55e1.c145)
  Auto-duplex, Auto-speed
  Last input never, output never, output hang never
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 packets output, 0 bytes, 0 underruns
Cisco871#sh interfaces fastEthernet 2
FastEthernet2 is up, line protocol is down
  Hardware is Fast Ethernet, address is 0022.55e1.c146 (bia 0022.55e1.c146)
Cisco871#sh interfaces fastEthernet 3
FastEthernet3 is up, line protocol is up
  Hardware is Fast Ethernet, address is 0022.55e1.c147 (bia 0022.55e1.c147)
  Last input 00:00:03, output never, output hang never
  5 minute input rate 0 bits/sec, 1 packets/sec
  5 minute output rate 0 bits/sec, 1 packets/sec
     11425043 packets input, 3183188727 bytes, 0 no buffer
     Received 2051 broadcasts, 0 runts, 0 giants, 0 throttles
     19751206 packets output, 3365019030 bytes, 0 underruns
Cisco871#sh interfaces fastEthernet 4
FastEthernet4 is up, line protocol is up
  Hardware is PQUICC_FEC, address is 0022.55e1.c14e (bia 0022.55e1.c14e)
  Internet address is XX.XX.XX.XX/XX
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:21, output 00:00:00, output hang never
  Input queue: 0/75/21315/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 51000 bits/sec, 1 packets/sec
     73285985 packets input, 3050327367 bytes
     Received 151035 broadcasts, 0 runts, 0 giants, 1658 throttles
     2485 input errors, 125 CRC, 116 frame, 0 overrun, 2360 ignored
     0 watchdog
     59864030 packets output, 2913176450 bytes, 0 underruns
Cisco871#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  administratively down down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    up
FastEthernet4              XX.XX.XX.XX     YES NVRAM  up                    up
Vlan1                      unassigned      YES NVRAM  administratively down down
NVI0                       unassigned      NO  unset  up                    up
Virtual-Template1          XX.XX.XX.XX  YES TFTP   down                  down
Vlan10                     192.168.0.1     YES NVRAM  up                    up
Vlan20                     192.168.1.1     YES NVRAM  up                    up
Vlan100                    unassigned      YES NVRAM  administratively down down
Vlan200                    unassigned      YES NVRAM  administratively down down
Vlan30                     192.168.2.2     YES NVRAM  administratively down down
Virtual-Access1            unassigned      YES unset  down                  down
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
What's your CPU stats look like when you hit 50 Mbps?  Reason I ask, an 871 is only rated at 25 Kpps.
Hi Joseph,
sorry, I didn't understand what do you mean?
Can you please explain me, how to check the CPU stats of the router?
MA
