(S,G) not forming in Source PE in SSM !!
muthupriyanka
  I have SSM configured in my MPLS core and for one of my customer too - VPN A. Multicast streaming is not woking for my customer.
  I checked the (S,G) by using the cmd "sh ip mroute vrf VPNA". I am able to see (S,G) forming in only receiver PE and not in source PE.
  I configured igmp join the interface of PE router where the receiver is connected.
PE2#
interface GigabitEthernet1/1
description "CUST-A MULTICAST TESTING"
ip vrf forwarding CUST-A
ip address 40.40.40.1 255.255.255.252
ip pim sparse-mode
ip igmp join-group 238.192.10.60 source 30.30.30.1
ip igmp version 3
end
PE2#
PE2#sh ip mroute vrf CUST-A
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group,
       V - RD & Vector, v - Vector
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.255.255.250), 02:28:52/00:02:02, RP 0.0.0.0, flags: SJC
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    GigabitEthernet1/1, Forward/Sparse, 02:28:52/00:02:02
(30.30.30.1, 238.192.10.60), 02:29:33/00:02:08, flags: sLTI
  Incoming interface: Tunnel0, RPF nbr 192.8.233.8
    GigabitEthernet1/1, Forward/Sparse, 02:29:33/00:02:08
(*, 224.0.1.40), 02:29:33/00:02:45, RP 0.0.0.0, flags: DCL
    Tunnel0, Forward/Sparse, 02:29:33/00:02:45
PE2#
I checked the Mtrace from PE1.It shows the below output.
PE1X#mtrace vrf CUST-A 30.30.30.1 40.40.40.1 238.192.10.60
Mtrace from 30.30.30.1 to 40.40.40.1 via group 238.192.10.60 in VRF CUST-A
From source (?) to destination (?)
Querying full reverse path... * switching to hop-by-hop:
0  40.40.40.1
-1  * 0.0.0.0 PIM/MBGP Admin. Prohibited [30.30.30.0/30]
-2  * 0.0.0.0 PIM  [30.30.30.1/32]
-2  30.30.30.1
PE1X#
PE1#sh run int Gi2/6
Building configuration...
Current configuration : 232 bytes
interface GigabitEthernet2/6
ip address 30.30.30.1 255.255.255.252
ip pim sparse-mode
ip igmp version 3
end
PE1#
PE1#sh ip mroute vrf CUST-A
(*, 239.255.255.250), 01:46:21/00:02:36, RP 0.0.0.0, flags: SJC
    GigabitEthernet2/6, Forward/Sparse, 01:46:21/00:02:36
(*, 224.0.1.40), 01:46:29/00:02:54, RP 0.0.0.0, flags: DCL
    Tunnel0, Forward/Sparse, 01:46:29/00:02:54
7 Replies 7
Giuseppe Larosa
Hello Muthupriyanka,
in order to get better help you should post the relevant configuration elements of PE2 and PE1 nodes.
I mean:
ip multicast routing enabled in global routing table
VRF configuration specially to see if you have an MDT
MP BGP configuration what type of address-family are you using in the control plane?
for each of PE1 and PE2.
Look also at the log messages on PE1 node.
The PE1 node should receive the PIM join from PE2 on the GRE tunnel interface
There are also some specific debug commands that can be used for this troubleshooting
debug ip pim vrf CUST-A
see the avaiable options there might be a reason that makes PE1 to refuse the PIM join coming from PE2 over the tunnel.
Hope to help
Giuseppe
Hi Giuseppe,
   Thanks for your reply.
    Below are the configurations from PE1.
PE1#sh run | b ip vrf CUST-A
ip vrf CUST-A
rd 24084:3001
route-target export 24084:303001
route-target import 24084:303001
mdt default 239.192.0.1
mdt data 239.192.10.0 0.0.0.255 threshold 1
PE1X#sh run | i multicast
ip multicast-routing
ip multicast-routing vrf CUST-A
PE1X#sh run | i ssm
ip pim ssm range 55
ip pim vrf CUST-A ssm range 65
PE1X#
PE1X#sh ip access-lists 55
Standard IP access list 55
    10 permit 239.192.0.0, wildcard bits 0.0.255.255 (85 matches)
PE1X#
PE1X#sh ip access-lists 65
Standard IP access list 65
    10 permit 238.192.10.0, wildcard bits 0.0.0.255 (840 matches)
PE1X#
PE1X#sh ip pim mdt
  * implies mdt is the default MDT
  MDT Group/Num   Interface   Source                   VRF
* 239.192.0.1     Tunnel0     Loopback0                CUST-A
PE1X#
PE1X#sh ip pim vrf CUST-A nei
PIM Neighbor Table
Mode: B - Bidir Capable, DR - Designated Router, N - Default DR Priority,
      P - Proxy Capable, S - State Refresh Capable, G - GenID Capable
Neighbor          Interface                Uptime/Expires    Ver   DR
Address                                                            Prio/Mode
192.8.233.7       Tunnel0                  1d21h/00:01:23    v2    1 / S P G
may you provide  the MP BGP configuration ?
I don't see it in your new post
From what I see it looks like fine
Hope to help
Giuseppe
Hi Larosa,
   Please find the MP-BGP configurations.
address-family ipv4 mdt
  neighbor rrvpnv4 send-community both
  neighbor x.x.x.x activate (RR1)
  neighbor y.y.y.y activate (RR2)
exit-address-family
address-family ipv4 vrf CUST-A
  no synchronization
  redistribute static
  redistribute connected
exit-address-family
Hello Muthu,
you are using the MDT address-family towards two route reflector servers.
But the MDT is a type of BGP extended community you need to send both standard or extended communities  in order to have them propagated from PE to PE via the RRS. In IOS communities are not sent by default.
Here it is my configuration for the same address family that I used some years ago:
Address-family ipv4 mdt
Neigh 10.80.0.21 activate
>>>Neigh 10.80.0.21 send-community both
Neigh 10.80.0.23 activate
>>>Neigh 10.80.0.23 send-community both
Explanation:
When BGP extended communities are used, the PE loopback (source address) information is sent as a VPNv4 prefix using Route Distinguisher (RD) Type 2 (to distinguish it from unicast VPNv4 prefixes). The MDT group address is carried in a BGP extended community. Using a combination of the embedded source in the VPNv4 address and the group in the extended community, PE routers in the same MVRF instance can establish SSM trees to each other.
see
http://www.cisco.com/en/US/docs/ios/ipmulti/configuration/guide/imc_cfg_mc_vpn_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1055404
Hope to help
Giuseppe
Hi Larosa,
    Send community is already configured under peer group if u notice in the above configuration.
router bgp 1234
bgp router-id z.z.z.z
bgp always-compare-med
no bgp default ipv4-unicast
bgp log-neighbor-changes
bgp deterministic-med
bgp graceful-restart restart-time 120
bgp graceful-restart stalepath-time 360
neighbor rrvpnv4 peer-group
neighbor rrvpnv4 remote-as 1234
neighbor rrvpnv4 update-source Loopback0
neighbor rrvpnv4 timers 10 30
neighbor x.x.x.x peer-group rrvpnv4
neighbor y.y.y.y peer-group rrvpnv4
exit-address-family
Please help...
I'm sorry I have missed you had a peer-group.
However, I would expect the following configuration in  BGP af mdt:
neighbor rrvpnv4 activate
Hope to help
Giuseppe
