Does it support ?
mrmozaffari
Emergency
Does WIC-1SHDSL module support G.hdsl or not ?
I know it supports G.shdsl but i want to know if it supports G.HDSL.
Thanks.
Edison Ortiz
Q. Do the G.SHDSL HWICs comply with G.hs?
A. G.hs is an integral part of G.992.1, the standard that the HWICs comply with, so the G.SHDSL HWICs do comply with G.hs, also known as G.994.1.
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/ps7175/prod_qas0900aecd80591ff1.html
HTH,
__
Edison.
Please rate helpful posts
