Does Packet Tracer Support Policy-Based Routing (PBR)?
AronTesfay0645
I'm using a couple of Cisco 2911 routers in Packet Tracer and was trying to implement Policy-Based Routing (PBR) using instructions from this link
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_pi/configuration/15-mt/iri-15-mt-book/iri-pbr.html
I know that the 2911 router supports PBR in real life but non of the commands in the configuration seem to be recognized in Packet Tracer.
luis_cordova
Hi @AronTesfay0645
In fact, the link commands you attach are not compatible with Packet Tracert.
You can check the allowed commands by clicking on the question mark inside the program:
I recommend that you use another simulation program, such as GNS3 or EVE, since Packet Tracert has limitations in the IOS of the devices.
Mark Elsen
 - It seems to be supported in XE , not sure for your platform :
     https://www.cisco.com/c/en/us/support/docs/quality-of-service-qos/policy-based-routing-pbr/200926-Configure-Packet-Trace-to-Debug-PBR-Traf.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
luis_cordova
Hi @AronTesfay0645
