Does PoE work over Cat5E?
news2010a
Level 7
Level 7
Folks, please confirm if you need Cat6 for PoE?
Edison Ortiz
Yes, POE works over Cat5e.
HTH,
__
Edison.
Rick Morris
Level 11
Level 11
Cat5e is rated for Gig speeds but they will not tolerate as much frequency interference as Cat 6 will.
Both are rated for Gig speeds, it is the interference that makes them different.
jeffreytheall
Community Member
cat5e is fine.
