does this platform support Netflow
hanyawad
below the sh ver command of my core switch and i'd like to know if it supports netflow. because i've tried to issue netflow commands but it rejects it. thanks for your help and recommendation.
Labib
CORE-01#sh ver
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(20)EWA3,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 07-Sep-05 17:29 by kesnyder
Image text-base: 0x00000000, data-base: 0x012244CC
ROM: 12.1(20r)EW1
Dagobah Revision 95, Swamp Revision 3
CORE-01 uptime is 5 weeks, 8 hours, 38 minutes
System returned to ROM by reload
System restarted at 15:18:10 EST Thu Nov 8 2012
System image file is "bootflash:cat4000-i9s-mz.122-20.EWA3.bin"
cisco WS-C4506 (MPC8245) processor (revision 4) with 262144K bytes of memory.
Processor board ID FOX073901MY
MPC8245 CPU at 266Mhz, Supervisor II+
Last reset from Reload
13 Virtual Ethernet/IEEE 802.3  interface(s)
96 FastEthernet/IEEE 802.3 interface(s)
56 Gigabit Ethernet/IEEE 802.3 interface(s)
511K bytes of non-volatile configuration memory.
Configuration register is 0x102
kcnajaf
Level 7
Level 7
HI,
This platform supports netflow. Please find the detials of fetures  supported by your IOS.
Feature Name
Address Resolution Protocol (ARP)
AppleTalk 1 and 2
Broadcast/Multicast Suppression
CDP (Cisco Discovery Protocol) Version 2
CEF/dCEF - Cisco Express Forwarding
CEFv6/dCEFv6 - Cisco Express Forwarding
CGMP - Cisco Group Management Protocol
CLI String Search
Cisco IP Phone Support
Class Based Ethernet CoS Matching & Marking (802.1p & ISL CoS)
Class-Based Marking
Class-Based Policing
Class-Based Shaping
Clear Counters Per Port
Commented IP Access List Entries
DAI (Dynamic ARP Inspection)
DBL (Dynamic Buffer Limiting) - Active Queue Management
DHCP Client
DHCP Relay Agent Support for Unnumbered Interfaces
DHCP Server
DHCP Snooping
Default Passive Interface
Diagnotics Options on bootup
Dynamic Trunking Protocol (DTP)
EGP
EIGRP Stub Routing
ErrDisable Reactivation Per Port
ErrDisable timeout
EtherChannel
EtherChannel - Flexible PAgP
FTP Support for Downloading Software Images
Fast EtherChannel (FEC)
Forced 10/100 Autonegotiation
Generic Routing Encapsulation (GRE)
HSRP - Hot Standby Router Protocol
HSRP support for ICMP Redirects
IEEE 802.1Q VLAN Support
IEEE 802.1Q VLAN Trunking
IEEE 802.1W Spanning Tree Rapid Reconfiguration
IEEE 802.1s VLAN Multiple Spanning Trees
IEEE 802.1t
IEEE 802.1x - VLAN Assignment
IEEE 802.1x Authenticator
IEEE 802.1x Guest VLAN
IEEE 802.1x RADIUS Accounting
IEEE 802.1x with Port Security
IEEE 802.3af PoE (Power over Ethernet)
IEEE 802.3x Flow Control
IGMP Fast Leave
IGMP Snooping
IGMP Version 1
IGMP Version 2
IGMP Version 3
IGMPv3 Snooping: Full Support
IP Enhanced IGRP Route Authentication
IP Multicast Load Splitting across Equal-Cost Paths
IP Named Access Control List
IP Routing
IP Source Guard
IP Summary Address for RIPv2
IPX Access Control List Violation Logging
IPX Access List Plain English Filters
IPX Named Access Lists
IPX SAP-after-RIP
IPv6 (Internet Protocol Version 6)
IPv6 Data Link: VLANs using IEEE 802.1Q Encapsulation
IPv6 MTU Path Discovery
IPv6 Multicast: PIM Source-Specific Multicast (PIM-SSM)
IPv6 Multicast: Scope Boundaries
IPv6 Neighbor Discovery
IPv6 Routing: IS-IS Multitopology Support for IPv6
IPv6 Routing: IS-IS Support for IPv6
IPv6 Routing: OSPF for IPv6 (OSPFv3)
IPv6 Routing: RIP for IPv6 (RIPng)
IPv6 Routing: Route Redistribution
IPv6 Routing: Static Routing
IPv6 Services: AAAA DNS Lookups over an IPv4 Transport
IPv6 Services: Cisco Discovery Protocol (CDP) - IPv6 Address Family Support for Neighbor Information
IPv6 Services: DNS Lookups over an IPv6 Transport
IPv6 Services: Extended Access Control Lists
IPv6 Services: Standard Access Control Lists
IPv6 Stateless Auto-configuration
IPv6 Switching: CEF/dCEF Support
IPv6: ICMPv6
IPv6: ICMPv6 Redirect
IPv6: Neighbor Discovery Duplicate Address Detection
ISIS
Inline Power Auto Negotiation
Inline Power Management
Interface Index Persistence
Interface Range Specification
Jumbo Frames
Link Aggregation Control Protocol (LACP) (802.3ad) for Gigabit Interfaces
Local Proxy ARP
Modular QoS CLI (MQC)
Multicast Source Discovery Protocol (MSDP)
NSF Awareness - EIGRP
NetFlow
NetFlow Aggregation
Netflow Data Export (NDE) Version 5
Network Time Protocol (NTP)
Novell IPX
PIM Dense Mode State Refresh
PIM Multicast Scalability
PIM Version 1
PIM Version 2
Pragmatic General Multicast (PGM)
Private VLAN Trunk Ports
QoS Packet Marking
RIP
RMON events and alarms
Rapid-Per-VLAN-Spanning Tree (Rapid-PVST)
Reduced MAC Address Usage
Remote SPAN (RSPAN)
SNMP (Simple Network Management Protocol)
SNMP Inform Request
SNMPv3 (SNMP Version 3)
Source Specific Multicast (SSM)
Spanning Tree Protocol (STP)
Spanning Tree Protocol (STP) - Backbone Fast Convergence
Spanning Tree Protocol (STP) - Loop Guard
Spanning Tree Protocol (STP) - PortFast BPDU Filtering
Spanning Tree Protocol (STP) - Portfast
Spanning Tree Protocol (STP) - Portfast BPDU Guard
Spanning Tree Protocol (STP) - Portfast Support for Trunks
Spanning Tree Protocol (STP) - Root Guard
Spanning Tree Protocol (STP) - Uplink Fast Convergence
Spanning Tree Protocol (STP) - Uplink Load Balancing
Standard IP Access List Logging
Sticky Port Security
Switch Port Analyzer (SPAN)
Switch Port Analyzer (SPAN) - CPU Source
TACACS+
Time-Based Access Lists
Uni-Directional Link Routing (UDLR)
Unidirectional Ethernet
Using 31-bit Prefixes on IPv4 Point-to-Point Links
VLAN Access Control List (VACL)
VLAN MAC Address Filtering
In future please use feature navigator on cisco website (below url) to verify what features are supported on individual platforms.
http://cisco.com/go/fn
Najaf
Please rate when applicable or helpful !!!
Don Jacob
What SUP Engine does your CAT 4000 switch have?
To use the NetFlow feature on a 4000 and 4500 series switches, you need to have either a Supervisor Engine IV or a Supervisor Engine V and along with this, a NetFlow Services Daughter Card (WS-F4531) should be installed additionally.
If you have Supervisor Engine V-10GE, (which I think is not available for the Cat 4000), the functionality is embedded in the supervisor engine and you only need to configure NetFlow.
Don Thomas Jacob
www.netflowanalyzer.com
NOTE: Please rate posts and close questions if you have got your answer.
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
