address traslation logging ASR1006
I would like to know if Cisco Collector Engine 6.0 can recive and reading the sent address traslation logging of router ASR1006. Using Netflow v9.
Juan
Don Jacob
Hi Juan,
I dint see this post from you till I answered a different post by you about NetFlow event logging for NAT translations from ASR. As per the below blog, it can.
http://ccieplayground.wordpress.com/2010/03/21/netflow-event-logger-on-asr1k/#more-32
Don Thomas Jacob
www.netflowanalyzer.com
NOTE: Please rate posts and close questions if you have got your answer.
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
Hello Tomas,
Know any other software that you can recommend me?
Juan
Hi Juan,
No NetFlow vendor I know currently supports it. You could try getting in touch with Plixer or ManageEngine NetFlow and ask if they can do this as a special request for you.
Don Thomas Jacob
Thank you Don. Yes we have support for ASR NAT reporting
Jake Wilson
NetFlow Knight
