Doesn't work QOS on 4451-X
Maxim Ototuk
I have a problem:
class-map match-all HTTS
match protocol http
match protocol secure-http
policy-map QOS
class HTTS
priority percent 10
class class-default
random-detect
policy-map int
class class-default
shape average 10000000
service-policy QOS
interface Tunnel1
bandwidth 10000
ip unnumbered Loopback9
ip mtu 1300
tunnel source a.b.c.d
tunnel destination a.c.b.d
service-policy output int
2016-03-17 15:45:01 local7.info  3883:  Service policy installation failed
2016-03-17 15:45:01 local7.info  3882: Mar 17 15:45:01.683: %QOS-6-POLICY_INST_FAILED:
What am I doing wrong?
2 Accepted Solutions
Could you upgrade to 3.16.2S or 3.13.5S?  I think what you are doing should work.
Hello.
Having QoS on Tunnel with port-channel as egress is not supported till XE 3.14 (CSCum12999).
13 Replies 13
Philip D'Ath
Break it done into smaller chunks to find out which bit is breaking it.
Does just this work?
policy-map int
class class-default
It also don't work.
So without a child policy it also fails?  What software version are you running?
The current gold star releases for the 4451 are 3.16.2S and 3.13.5S.  If you aren't using one of them I would try changing to one of them first.
This time, I can't  download this image.
You can only download the software if you have a Cisco maintenance contract.  Have you got a contract on the 4451?
policy-map int-2
class class-default
interface Tunnel1
bandwidth 10000
ip mtu 1300
service-policy output int-2
 It also don't work.
String don't save in running-config.
System image file is "bootflash:/isr4400-universalk9.03.13.02.S.154-3.S2-ext.SPA.bin"
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appx None None None
uc uck9 Permanent uck9
security securityk9 Permanent securityk9
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4451-X/K9 (2RU) processor with 1687596K/6147K bytes of memory.
Processor board ID
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7341807K bytes of flash memory at bootflash:.
On physical interface policy is working....
Hello.
Could you check "show ip cef ..." for tunnel destination and provide sh runn for the egress interface[s]?
If you have QoS on the interface[s], could you provide policy-map configuration?
PS:
configuration
match protocol http
sounds a little strange to match both "http" and "secure-http".
interface Tunnel1
bandwidth 10000
ip mtu 1300
ip authentication mode eigrp 65040 md5
ip authentication key-chain eigrp 65040 EIGRP-65040
ip hello-interval eigrp 65040 3
ip hold-time eigrp 65040 10
ip tcp adjust-mss 1260
keepalive 10 2
tunnel source Port-channel1.305
tunnel destination x.x.46.2
#sh ip cef x.x.46.2
x.x.46.2/32
attached to Port-channel1.305
interface Port-channel1.305
encapsulation dot1Q 305
ip address x.x.0.3 255.255.128.0
interface GigabitEthernet0/0/0
no ip address
speed 1000
no negotiation auto
channel-group 1
interface GigabitEthernet0/0/2
no ip address
speed 1000
no negotiation auto
channel-group 1
#sh ip eigrp neighbors Tunnel1
H          Address         Interface    Hold       Uptime      SRTT   RTO  Q Seq
13    y.y.221.255            Tu1           9      21:38:30 31   186         0     233489
- Why?
class-map is more. I'm using it for checking.
Hello.
Thanks.
