DOM capability and compability with Cisco 3945
Djule2804
Hi all,
I'm requesting your help regarding the Transceiver integration within Cisco 3945.
I need to supervise the DOM (Digital optical monitoring) capability of  LX laser integrated within CISCO 3945.
But after study of the Cisco DataSheet on transceiver module compability:
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
I've seen that the SFP-GE-L model which supports DOM cannot be integrated within Cisco 3945.
As specified in the datasheet, the only model of LX lasers compliant with CISCO 3945 is  GLC-LH-SM (without DOM).
However, after study of this datasheet, I can see that Cisco propose this Tranceiver model with DOM capability: GLC-LH-SMD
But, so far I can't figure out if this model (GLC-LH-SMD) with the DOM capability is supported on Cisco 3945 and can be monitored through monitoring tools?
If not, is there an other alternative to supervise the DOM capability with transceiver (LX) to be intergated within Cisco 3925?
Thank you very much in advance for your response.
Julien
Jerry Ye
According from the following PDF, Table 11, none of the DOM supported SFPs are compatible with the 3900 series routers currently.
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.pdf
My understanding is the GLC-LH-SMD will replace the GLC-LH-SM eventually.
HTH,
jerry
