Double InterNet Router
battanc
Local LAN with two InterNet-Router:
- Cisco/1801 for ADSL line(flat princing)
- Cisco/1700 for HDSL line (traffic pricing)
The internal LAN is connected to the Eth-0 of the Cisco/1801
The Cisco/1700 is connected to the Eth-1 of the Cisco/1801
Because of the costs, the HDSL line is to be used ONLY for the VPN (one site-to-site and several clients).
HDSL has a public static IP address.
Internet navigation, generic download, Mail, etc. have to use ADSL line.
I can configure the Cisco/1801 to have ADSL connection and the site-to-site VPN working, but I can not connect from outside with the client VPNs.
In fact, pinging from outside the public address (HDSL local VPN peer) I receive responde from the ADSL public IP (dynamic).
I tried several static routes and several ACLs, but I can not find a right configuration.
Some suggestion?
paolo bevilacqua
Do you have static nat on the 1700 ?
I'm not sure what you are pinging, for the VPN client issue, but if you ping the HDSL address it seems strange the ADSL responds.
