Double NAT broke: config is the same
jcw009
Hi all,
I configured a router to do double nat (overlapping ip addresses) a while back. Now, suddenly, my users report that they cannot access the server by it's nat'd address. when they traceroute to the nat'd address, it traces to the router doing the natting, when i ping/tracert to the router, from the server, it works. I cannot ping/tracerouter through the natting router.
I'm looking at the config, and it should be working. The only changte that has been made in the past couple of months, is that I removed a router from the path, implementing vlans, but I've modified the routes on the devices between the server and the natting router, adn the tracert works! Arrgh.
Here's the current running-config of the natting router.
rtr-PDCity#sh ru
Building configuration...
Current configuration : 1378 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname rtr-PDCity
logging buffered 4096 debugging
no logging console
enable secret xxx
enable password xxx
ip subnet-zero
interface Loopback0
no ip address
interface Ethernet0
description connected to County Network
ip address 10.90.204.12 255.255.255.128
ip nat outside
full-duplex
interface FastEthernet0
description connected to City Network
ip address 10.20.14.100 255.255.0.0
ip nat inside
speed auto
half-duplex
ip nat pool city 192.168.69.17 192.168.69.22 netmask 255.255.255.248
ip nat inside source list 1 pool city
ip nat outside source static 192.168.5.11 192.168.69.2
ip classless
ip route 0.0.0.0 0.0.0.0 10.90.204.1
ip route 10.10.0.0 255.255.0.0 10.20.14.31
ip route 10.70.0.0 255.255.0.0 10.20.14.31
ip route 192.168.20.50 255.255.255.255 10.90.204.1
ip route 192.168.69.2 255.255.255.255 Ethernet0
ip route 192.168.69.16 255.255.255.248 FastEthernet0
no ip http server
access-list 1 permit 10.70.0.0 0.0.255.255
access-list 1 permit 10.20.0.0 0.0.255.255
access-list 1 permit 10.10.0.0 0.0.255.255
snmp-server community public RO
line con 0
password xxx
login
line aux 0
password xxx
login
line vty 0 4
password xxx
login
end
rtr-PDCity#
Server 192.168.5.11
ASA
Router
L3Switch
|vlan 16
natting router
router
clients
Thanks for any help!
-Jeff
ohassairi
Level 5
Level 5
in such situation i prefer you use a sniffer (etherreal) in inside and outside the nating router to see what hapens exactly, then you can follow the packet till the destination and find who is the wrong point!
etherreal is freeware, think to use filters when capturing
