3x WAN + QOS + Failover
razzarphenix
Hey Guys, Ive got 3 internet connections 1 on a 10meg fibre that comes in on ethernet port, two on adsl (terminated by adsl routers). The adsl links are around 7megs down 600k up so now what is the best router to purchase to load balance across all three, and failover if one link stops responding?
paolo bevilacqua
the minimum would be a 1841 with 2 x HWIC-1ADSL.
You can also look at the 2801 if you like it better. Both will do the job.
