12-20-2006 06:44 AM - edited 03-04-2019 03:09 AM
I'm struck with a situation where in our management wants to extend a WAN Link to one of our customer sites, and since there is a conflicting IP Addressing Scheme (we both have 10.120.X.X).
Hence, a solution has been suggested by using NAT on the Router with a Proxy Address (or NATted IP Address of 192.168.5.55).
Could anyone please point out a URL which describes my situation with a solution.
Kind Regards,
Wilson Samuel
12-20-2006 07:59 AM
and what about the subnetmask... it is also identical or what?
and will you please give me the more detail for the same issue?
regards
Devang
12-20-2006 08:25 AM
Hi Devang,
Thanks for the response.
Infact the situation is something like this:
1. Our Subnet is 10.120.x.x and our client's subnet is also of the same range.
2. There is one server at our end which is of 10.120.11.15/16 and there is a Server at the other end which is of 10.120.14.15/16
3. Both the Servers should be able to talk to each other in order to make the things work.
4. Now we want to translate their Server 10.120.14.15 = 192.168.12.15/28 and Our Server to be translated as 192.168.14.15/28 so that there is no confusion in our exisiting Routing infrastructure.
Now the issue is that on our Border Router this translation should take place:
1. The Server at our end neednt know the actual IP Address of the SErver at our client side i.e. 10.120.14.15/16 but would be configured to use the Destination IP as 192.168.14.15/28.
Similarly the Server at the client side needn't to know our Server's actual address ie.10.120.11.15/16 but should be configured to use 192.168.12.15/28 as the destination address.
Any help would be great.
Wilson Samuel
12-20-2006 08:40 AM
Try this document to start.
It has some examples of how to do this this.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080093f30.shtml
Now if there was not a exact duplication you might get by putting /32 static routes in. The router since it has a /32 will respond to a arp (proxy arp) and then send the traffic to the other interface. This is not the best thing to do but is useful as you migrate address ranges.
