Still having problems with .tar files IOS upgrade for a switch
jcutler0622
Ok I have a standard set up I have my local pc connected to the switch. I have configured VLAN1 with an ip on the same subnet as my machine. I am able to ping. Below is the config that I placed in the router as well as the error that I received. I have done multiple IOS upgrades but nothing like this.
Switch# archive download-sw /overwrite /reload tftp:[[//location]/directory]/image-name.tar
This is what my input was into the switch:
Switch# archive download-sw /overwrite /reload tftp:F:\ntcc\Cisco\Ci
sco-IOS\3750\c3750-ipbasek9-tar.122-25.SEE2.tar
This is the error that I am getting.
Switch#$overwrite /reload tftp:[[//location]/directory]/image-name.tar
Could not buffer tarfile...using multiple downloads
examining image...
%Error opening tftp:[[//location]/directory]/image-name.tar (Invalid IP address
or hostname)
%Error opening flash:update/info (No such file or directory)
ERROR: Image is not a valid IOS image archive.
Please confirm!!! all the forward slashes are right and what not lol. I need to get this done ASAP so PLEASE HELP :)
I will rate once problem has been completed.
Wilson Samuel
Level 7
Level 7
Dear Jcutler,
Please use the WinRAR software (http://www.rarlab.com/) and avoid all these confusions. Please write me back if you are still struck with the situation.
Wilson Samuel
Sorry I can't do it this way....I need to write a procedure doing it the Cisco way :).
I can't dowload 3rd party software to this machine.
Anyone else please help!!!
Cisco does not use mircosoft file shares. You must have a tftp server on your machine.
If has no clue what to do with F:\ntcc\cisco.....
It basically will take a ip address here and you can put directories in but it easier to configure the tftp server so the default directory already maps where you want it.
