Dropping scavenger packets on ASR 9000 during congestion
Prashanth Kumar
I am trying to find a solution using modular QOS when there is congestion in circuit we drop packets with WRED which are marked with a DSCP value of say AF21. I can drop those traffic completely in case of congestion.  I was thinking to allocate 100% bandiwth to rest of the traffic. Will this work or is thre any other elegant solution.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Generally (W)RED is only suitable for rate adaptive traffic, and if the traffic is rate adaptive, you usually don't want to drop all such traffic's packets.
WRED can be used to create drop tiers for rate non-adaptive traffic.
On sub Ethernet bandwidth links, with few flows, I've found drop management better with FQ per flow queue depths.
RED works better with Ethernet or better bandwidths with many flows, especially when FQ not avaible.
Depending on platform, FRED or DBL might be more elegant options.
Much depends on your service requirements.
