Some part of IP addresses are not seen through GRE tunnel
a_prutkoy
The GRE tunnel.
Cisco 2821 [GE0/0] --- Public Internet --- [FE0/0] Cisco 2801
Cisco 2821:
interface Tunnel0
description GRE tunnel to back office
ip address 172.16.0.2 255.255.255.252
ip mtu 1400
ip tcp adjust-mss 1360
tunnel source GigabitEthernet0/0
tunnel destination 94.xxx.xxx.254
interface GigabitEthernet0/0
description $Connect-to-upstream-C2901$
ip address 91.xxx.xxx.254 255.255.255.252
ip access-group 101 in
no ip unreachables
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.102.250 255.255.255.0
ip nat inside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 91.xxx.xxx.253
ip route 192.168.101.0 255.255.255.0 172.16.0.1
Cisco 2801:
interface Tunnel0
description GRE tunnel to main office
ip address 172.16.0.1 255.255.255.252
ip mtu 1400
tunnel source FastEthernet0/0
tunnel destination 91.xxx.xxx.254
interface FastEthernet0/0
ip address 94.xxx.xxx.254 255.255.255.252
no ip unreachables
duplex auto
speed auto
crypto map dynmap
interface FastEthernet0/1
ip address 192.168.101.250 255.255.255.0
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 94.xxx.xxx.253
ip route 192.168.102.0 255.255.255.0 172.16.0.2
show arp from 2801:
2801-voip-gw#sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  94.xxx.xxx.253         235   001c.f630.5435  ARPA   FastEthernet0/0
Internet  94.xxx.xxx.254           -   0014.1c62.0384  ARPA   FastEthernet0/0
Internet  192.168.101.10          3   1c17.d341.135f  ARPA   FastEthernet0/1
Internet  192.168.101.13         32   0021.5555.3b32  ARPA   FastEthernet0/1
Internet  192.168.101.15         17   dc7b.94f8.022a  ARPA   FastEthernet0/1
Internet  192.168.101.16          6   dc7b.94f8.e6af  ARPA   FastEthernet0/1
Internet  192.168.101.18          8   001f.9e24.a19c  ARPA   FastEthernet0/1
Internet  192.168.101.19         21   001e.7ac5.7a82  ARPA   FastEthernet0/1
Internet  192.168.101.20          0   001e.7ac5.7a24  ARPA   FastEthernet0/1
Internet  192.168.101.21          6   001e.7a26.1fc7  ARPA   FastEthernet0/1
Internet  192.168.101.25         36   0021.5554.7ca9  ARPA   FastEthernet0/1
Internet  192.168.101.26         23   001f.9eac.dbe7  ARPA   FastEthernet0/1
Internet  192.168.101.251         1   0015.605f.a46e  ARPA   FastEthernet0/1
Internet  192.168.101.252         0   0013.21b5.c158  ARPA   FastEthernet0/1
ping from 2821:
2821-voip-gw#ping 172.16.0.1
Sending 5, 100-byte ICMP Echos to 172.16.0.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/8 ms
2821-voip-gw#ping 192.168.101.250
Sending 5, 100-byte ICMP Echos to 192.168.101.250, timeout is 2 seconds:
2821-voip-gw#ping 192.168.101.10
Sending 5, 100-byte ICMP Echos to 192.168.101.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 68/70/72 ms
2821-voip-gw#ping 192.168.101.251
Sending 5, 100-byte ICMP Echos to 192.168.101.251, timeout is 2 seconds:
Success rate is 0 percent (0/5)
ping from 2801:
2801-voip-gw#ping 192.168.101.251
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
As you can see, I can ping some IP addresses on site 2801 but some can't. The same situation if I ping network on site 2821.
show arp from 2821:
2821-voip-gw#sh arp
Internet  91.xxx.xxx.253        146   e8b7.48c3.a641  ARPA   GigabitEthernet0/0
Internet  91.xxx.xxx.254          -   dc7b.94d8.b960  ARPA   GigabitEthernet0/0
Internet  192.168.102.10         24   c40a.cbe1.e6e3  ARPA   GigabitEthernet0/1
Internet  192.168.102.11          0   001b.38ad.9250  ARPA   GigabitEthernet0/1
Internet  192.168.102.12          0   70ca.9b5c.5ec1  ARPA   GigabitEthernet0/1
Internet  192.168.102.13          0   ccef.48a2.7a7a  ARPA   GigabitEthernet0/1
Internet  192.168.102.250         -   dc7b.94d8.b961  ARPA   GigabitEthernet0/1
ping from 2801:
2801-voip-gw-akvalis#ping 192.168.102.10
Sending 5, 100-byte ICMP Echos to 192.168.102.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/7/8 ms
2801-voip-gw-akvalis#ping 192.168.102.11
Sending 5, 100-byte ICMP Echos to 192.168.102.11, timeout is 2 seconds:
ping from 2821:
2821-voip-gw-akvalis#ping 192.168.102.11
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Can somebody help to understand why some IPs are seen and some not through GRE tunnel?
a_prutkoy
I have found the issue.
