Drops Due to Buffer Failures on 2921
trey.s.grunDD
All,
I am attempting to determine how to remediate drops that I believe are caused by buffer failures on a 2921 ISR. The relevant interface statistics are:
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/0/377 (size/max/drops/flushes); Total output drops: 83
Queueing strategy: fifo
The relevant buffer data is:
2921#show buffer
Buffer elements:
1249 in free list
54679483 hits, 0 misses, 2268 created
Public buffer pools:
Small buffers, 104 bytes (total 95, permanent 50, peak 150 @ 6d15h):
89 in free list (20 min, 150 max allowed)
67415929 hits, 5810 misses, 6477 trims, 6522 created
572 failures (0 no memory)
Middle buffers, 600 bytes (total 20, permanent 25, peak 115 @ 1w0d):
16 in free list (10 min, 150 max allowed)
24912561 hits, 2150 misses, 4642 trims, 4637 created
148 failures (0 no memory)
Big buffers, 1536 bytes (total 133, permanent 50, peak 329 @ 3w0d):
132 in free list (5 min, 150 max allowed)
17161476 hits, 11530 misses, 34480 trims, 34563 created
1 failures (0 no memory)
VeryBig buffers, 4520 bytes (total 10, permanent 10, peak 11 @ 3w0d):
10 in free list (0 min, 100 max allowed)
1814389 hits, 0 misses, 1 trims, 1 created
0 failures (0 no memory)
Large buffers, 5024 bytes (total 1, permanent 0, peak 1 @ 3w0d):
1 in free list (0 min, 10 max allowed)
0 hits, 0 misses, 191 trims, 192 created
Huge buffers, 18024 bytes (total 5, permanent 0, peak 8 @ 5d13h):
5 in free list (4 min, 10 max allowed)
168001 hits, 1 misses, 383 trims, 388 created
Interface buffer pools:
CF Small buffers, 104 bytes (total 101, permanent 100, peak 101 @ 3w0d):
101 in free list (100 min, 200 max allowed)
Onboard DSPRM Pool buffers, 264 bytes (total 300, permanent 300):
0 in free list (0 min, 300 max allowed)
300 hits, 0 fallbacks
300 max cache size, 300 in cache
702738 hits in cache, 0 misses in cache
Cellular eHWIC IPC buffers, 512 bytes (total 257, permanent 257):
0 in free list (0 min, 257 max allowed)
257 hits, 0 misses
257 max cache size, 255 in cache
1437653 hits in cache, 0 misses in cache
Generic ED Pool buffers, 512 bytes (total 101, permanent 100, peak 101 @ 3w0d):
101 in free list (100 min, 100 max allowed)
0 hits, 0 misses
CF Middle buffers, 600 bytes (total 101, permanent 100, peak 101 @ 3w0d):
The Interface showing these drops is configured as follows:
1#show run int g0/1
Building configuration...
Current configuration : 425 bytes
interface GigabitEthernet0/1
description Broadband Connection
ip address x.x.x.x x.x.x.x
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow monitor NTAmon input
ip flow monitor NTAmon output
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly in
ip virtual-reassembly out
cws out
zone-member security outside
duplex auto
speed auto
no cdp enable
no mop enabled
end
There are tunnel interfaces configured that use this interface as a source that show even more drops, but since those are virtual interfaces, I count those drops as virtual drops, etc - besides, tunnels always have screwy stats.
As I understand the mechanics of buffer failures and how they lead to drops - it's basically a result of packets getting lost as the CPU tries to find a buffer from which to transmit it from.
My understanding however, comes from this 13 year old document.
https://www.cisco.com/c/en/us/support/docs/interfaces-modules/channel-interface-processors/14620-41.html
The most recent "troubleshooting" document seemingly based on this information does not seem to cover the ISR platform - https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/15091-buffertuning.html
And understandably, the old "buffer tuning tool" has been deprecated and is no longer available.
My big question is - how can I confirm that the current interface configuration is the cause of the buffer failures and in-turn that the buffer failures are the cause of the drops without removing configurations until the failures and drops stop.  Is there a less primitive and intrusive method of verifying this?
Joseph W. Doherty
I don't know if your 2921 supports the global command "buffers tune automatic", but you might try that.
For your interface ingress and egress drops, you might try increasing the queue sizes. (I recall you can usually even go to max for ingress without causing router issues.)
Giuseppe Larosa
Hello Trey,
looking at the output of show buffer on your router we see that there are misses and failures only in the public buffer pools. There are no misses in the interface pools section.
So I would say that your current configuration and/or the traffic properties might be the root cause for having a meaningful portion of user traffic sent to the main cpu ( in old terms process switched) and packets punted to the main cpu need to be stored in the public buffers according to their size.
I mean that it is not only the physical outside interface configuration involved here, the whole configuration should be reviewed and also user traffic characteristics should be considered.
As suggested by Joseph you can increase the size of the input and output hold queues on the interface and this can be of help.
Hope to help
Giuseppe
in addition to the other posts, you could also try and adjust the buffers, such as below (in global configuration mode):
buffers small permanent 150
buffers small min-free 50
buffers small max-free 450
buffers middle permanent 150
buffers middle min-free 50
buffers middle max-free 450
buffers big permanent 150
buffers big min-free 50
buffers big max-free 450
