dscp marking on DMVPN
mickd08
Hello, I have an Internal private network over which a DMVPN is running. I am wanting to mark all packets egress from the hub and spoke routers to be marked dscp 46 such that the IPSEC-GRE packets will traverse the private network with expedience. Is it the best way to do this by simply applying the service-policy to the physical WAN interface of the the hub and spoke routers ?
i.e.
policy-map all-traffic
class class-default
set ip dscp EF
int WAN
service-policy output all-traffic
basically for this to work, you apply the service policy to the physical interface, and then configure 'qos pre-classify' on the tunnel interfaces.
interface Serial0/0/0
service-policy output QoS_Policy
interface Tunnel0
qos pre-classify
balaji.bandi
in short answer possible, again depends on how you doing end to end qos.
https://ieoc.com/discussion/15001/dscp-markings-on-a-dmvpn-tunnel
BB
interface Tunnel0
qos pre-classify
