DSL controller problem
yavuz.ozdemir
I've a problem with my DSL controller, I configured this one but the controller is flapping UP-DOWN-UP-DOWN, I tried several parameters but still NOK, have you an idea why? Thanks in advance.
HERE's my config.
controller DSL 0/0/0
mode atm
line-term cpe
line-mode auto
dsl-mode shdsl symmetric annex B
Do it can be due to the firmware on the controller?
paolo bevilacqua
When reporting problems, at the minimum, always include router model and exact IOS used.
Sorry, here's more info. :
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(17a), RELEASE SOFTWARE (fc)
Cisco 2811 (revision 53.50) with 251904K/10240K bytes of memory.
Processor board ID FCZ120273RJ
1 DSL controller
2 FastEthernet interfaces
4 ISDN Basic Rate interfaces
1 ATM interface
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Router#sh controllers dsl 0/0/0
DSL 0/0/0 controller DOWN
SLOT 0: Globespan xDSL controller chipset
DSL mode: Not Trained
Frame mode: Utopia
Configured Line rate: 4608Kbps
Line Re-activated 53 times after system bootup
LOSW Defect alarm: ACTIVE
CRC per second alarm: ACTIVE
Line termination: CPE
FPGA Revision: 0xB2
Line 0 statistics
Current 15 min CRC: 0
Current 15 min LOSW Defect: 0
Current 15 min ES: 0
Current 15 min SES: 0
Current 15 min UAS: 180
Previous 15 min CRC: 0
Previous 15 min LOSW Defect: 0
Previous 15 min ES: 0
Previous 15 min SES: 0
Previous 15 min UAS: 871
Line 1 statistics
Current 15 min UAS: 203
Previous 15 min UAS: 737
Line-0 status
Chipset Version: 0
Firmware Version: R3.0.1
Modem Status: Handshake, Status 10
Last Fail Mode: No Failure status:0x0
DSL firmware download in progress, please wait
Line-1 status
Chipset Version: 0
Dying Gasp: Present
I don't think it's normal that you have "DSL firmware download in progress, please wait".
If you upgrade to at least to 12.4(6)T, this will give you latest 3.0.5 firmware, as explained at:
http://cisco.com/en/US/prod/collateral/routers/ps221/prod_bulletin0900aecd801d5c4c.html
