DSL Load balancing product
pbwild
Hallo,
I'm new here and am looking for the following:
a 4 port (load balanced) ADSL to GB Ethernet router, with VPN and firewall. Can you advise me which of your products best suits these requirements?
Many thanks,
Peter Wild
paolo bevilacqua
You can use a 2811 with 4 x HWIC-1ADSL interfaces. Due to the NAT configuration generally used, it can load balance internet access over all links.
Please rate post if it helps!
