DSL speed issues
kradjesh13
One of our customer is experiancing speed issues. Cannot figure out about the actual issue which causes the issue.
i am posing some of the outputs which i used for trouble shooting.
# sh processes cpu | i ^PID| Input
11 46632 230908 201 0.00% 0.00% 0.00% 0 ARP Input
39 13272 302232 43 0.00% 0.00% 0.00% 0 Net Input
46 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM Input
62 173320 1160922 149 0.07% 0.01% 0.00% 0 IP Input
87 0 2 0 0.00% 0.00% 0.00% 0 ILMI Input
92 0 2 0 0.00% 0.00% 0.00% 0 SSCOP Input
98 0 2 0 0.00% 0.00% 0.00% 0 ATMSIG Input
114 0 1 0 0.00% 0.00% 0.00% 0 RARP Input
#sh interfaces fastEthernet 0/0 switching
Protocol IP
Switching path Pkts In Chars In Pkts Out Chars Out
Process 193016 29773395 315693 23555166
Cache misses 0 - - -
Fast 24499820 2026836819 17236671 3245307143
Auton/SSE 0 0 0 0
#sh interfaces fastEthernet 0/0 | i rate
Queueing strategy: fifo
5 minute input rate 46000 bits/sec, 64 packets/sec
5 minute output rate 90000 bits/sec, 43 packets/sec
Sh dsl interface atm 0/1/0
Interleave Fast Interleave Fast
Speed (kbps): 0 1536 0 512
Cells: 0 84037571 0 1559364277
Reed-Solomon EC: 0 0 0 1
CRC Errors: 0 440 1 678
Header Errors: 0 144 2 252
Bit Errors: 0 0
BER Valid sec: 0 0
BER Invalid sec: 0 0
If possible, can some one suggest me what is the cause of the problem.
sbilgi
Level 5
Level 5
configure under the dialer interface 'ip mtu 1492'.
Also configure 'ip adjust-mss 1452' under the ethernet interface.
