DSU BANDWIDTH
Why do we use DSU bandwidth on interface ? .
I got a request to change DSU bandwidth on WAN interface  from its default to some value. But when i changed the value on WAN interface the link went down .
Again i had to login via Modem and revert the settings to  up the circuit .
Can anybody tell if that value has to match at service provider also ?
Answers will be helpful for me to resolve the case :) .
Richard Burts
DSU bandwidth is quite different from normal interface bandwidth and is only used on certain interface connections. When used the DSU bandwidth does change the operation of the interface controller/modem interface and does need to match the setting of the provider.
Rick
Rick
