Dual Broadband connection with 1841 ?
alanhong
Hi ,
i have have two broadband connections(PPPOE)(RJ45) for my office  and i want to know if there is a way i can Bundle them or load balance these lines on 1841router or any other router.please advise.
Laurent Aubert
Bundling several PPPoE links does work but it's not officially supported (please contact your local account team to have lattest info about the roadmap).
The main restriction is to use a single ISP for all the connection which support this feature as well so you need to contact it.
A simpler solution is to do cef load-balancing by configuring two different dialer interfaces (one per link) and having two default routes in the routing table.
Laurent.
