- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
05-17-2019 05:09 AM - edited 05-17-2019 05:11 AM
Hi everyone
I have a extraordinary question
I have one hub and many spokes already configured (single DMVPN, EIGRP, IPSec)
And i want to reconfigure my network as Dual HUB, dual DMVPN. Is it possible to make one of the spokes to be HUB2 and still stay as a spoke? Example: Spoke 1 = Hub2+Spoke1. How the config would look like?
for more information open the attached image please (black line is existing network and red arrows are network what I want to create)
Existing config:
Hub
interface Tunnel1
description ## Interface VPN Cloud ##
ip address 172.10.10.1 255.255.255.0
no ip redirects
ip mtu 1400
no ip next-hop-self eigrp 1
no ip split-horizon eigrp 1
ip nhrp network-id 1
tunnel source GigabitEthernet0/0/1
tunnel mode gre multipoint
Spoke 1
interface Tunnel1
ip address 172.10.10.2 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map multicast X.X.X.X
ip nhrp map 172.10.10.1 X.X.X.X
ip nhrp nhs 172.10.10.1
Solved! Go to Solution.
- Labels:
Other Routers
Routing Protocols
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-19-2019 03:07 AM
Hello Incognito,
what you need to do is the following:
a) on Spoke1 = Hub2 shut down interface tunnel1 the mGRE tunnel to DMVPN1.
allocate a private IP subnet like 10.10.12.0/30 to be used on the point to point tunnel
configure the tunnel with
interface tunnel 12
description HUB2 To HUB1 tunnel
ip address 10.10.12.2 255.255.255.255.252
tunnel source x.x.x.x
tunnel destination y.y.y.y
no shut
Under router eigrp process add a network statement for the new subnet
router eigrp 100
network 10.10.12.0 0.0.0.3
b)
on HUB1
create the tunnel 12
interface tunnel 12
description HUB1 To HUB2 tunnel
ip address 10.10.12.1 255.255.255.255.252
tunnel source y.y.y.y
tunnel destination x.x.x.x
no shut
router eigrp 100
c)
For encryption you should use the tunnel protection command with an IPSec profile.
However, I'm not sure it is supported on a point to point GRE tunnel.
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-17-2019 05:39 AM
Hello Incognito,
Well in real world Spoke1 would be remote far away from the Central site.
You should think of using a dedicated HUB for the second DMVPN.
Then of course you need to provide a routed link between HUB1 and HUB2 with EIGRP running over it.
This allows to cover some fault cases as spoke to spoke dynamic tunnel setup is limited to a single DMVPN.
see the following design guide on page 16
https://community.cisco.com/legacyfs/online/legacy/3/9/5/26593-DMVPNbk.pdf
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-18-2019 12:19 AM - edited 05-18-2019 01:01 AM
Thank you
And you recommend me to use another new hub and do not use the spoke as a hub? And my plan is unreal?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-18-2019 01:03 AM
Hello incognito,
yes I would recommend deploying a dedicated router as new HUB for new DMVPN
The reason is that for covering some type of faults you need routing between the two HUB routers.
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-18-2019 07:53 AM - edited 05-18-2019 07:58 AM
What if I just configure gre tunnel between hub and spoke1 (in this case hub2)??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-18-2019 09:22 AM - edited 05-18-2019 09:23 AM
Hello Incognito,
if you use a dedicated point to point GRE tunnel protected by IPSec to connect HUB1 and new HUB2 = spoke1, and you remove spoke1/HUB2 from DMVPN1, I think it is a reasonable design.
You need to run EIGRP over the new tunnel between the two HUB routers.
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-19-2019 01:08 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-19-2019 03:07 AM
Hello Incognito,
interface tunnel 12
no shut
router eigrp 100
b)
on HUB1
interface tunnel 12
no shut
router eigrp 100
c)
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-20-2019 10:08 AM
