DUAL DMVPN eigrp OSPF problem
james_son
Router MPLS <-->  Hub 1 dual DMVPN <--> Spoke1
MPLS is running OSPF and Hub1 see mpls ospf as external
Hub1 is doing mutual Redistributed  between OSPF and eigrp.
HUB only has one active phase 1 connection and failover to second hub.
DMVPN hub1 ospf Redistributed to eigrp tunnel then to Spoke eigrp Redistributed to ospf
My problem is on the spoke eigrp can't see the external route forwarding to the MPLS router.
Hub one has no problem reaching the MPLS but Spoke can reach the hub but can't reach the MPLS
i'm thinking OSPF Forwarding Address from external  routes.
What can I do ?????????
Paul Chapman
Level 4
Level 4
Hi -
Is this an IWAN build?  Can you post your configs (passwords / public IPs removed)?
PSC
Hello
How are you redistributing OSPF- Are you including it to advertise both internal and external prefixs
redistribute ospf xx match external internal
res
Paul
Kind Regards
Paul
