11-28-2013 12:12 AM - edited 03-04-2019 09:42 PM
HI guys,
I have implemented my scenarion following a helpful link from a guy in the forum (https://supportforums.cisco.com/docs/DOC-8313
What i actually want to implement is the below
i want my users to access the internet (80,443,and some ports of office 365 exchange online which i have openned) from provider A and only for the traffic i already mentioned.
Provider B should take over for the above mentioned traffic only when provider A is down otherwise provider B should be translating anything else (icmp, telnet, etc).
If either provider is down the other should be responsible for all traffic.
The problem begins when i have both interfaces up , nat translations for the web comes from both ISPS one packet is translated from provider A the other from Provider B. So the page takes too long to open.
See below my configuration and let me know if i have to change something either in the PBR logic or my access-lists that are connected to the PBR to correct this issue.
Current configuration : 19481 bytes
version 12.4
service password-encryption
hostname test
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 32568
aaa new-model
aaa session-id common
clock timezone EEDT 2
clock summer-time EEDT recurring last Sun Mar 3:00 last Sun Oct 4:00
dot11 syslog
ip source-route
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip cef
ip domain name neocleous.com
ip inspect tcp reassembly queue length 756
ip inspect name CBAC tcp
ip inspect name CBAC udp
ip inspect name CBAC icmp
ip inspect name CBAC ftp
ip inspect name CBAC http
ip inspect name CBAC imap
ip inspect name CBAC imap3
no ipv6 cef
voice dsp waitstate 0
voice-card 0
no dspfarm
track 1 ip sla 1 reachability
delay down 1 up 1
track 2 ip sla 2 reachability
delay down 1 up 1
interface FastEthernet0/0
description PRIMETEL
bandwidth 8000
ip address [public ip] 255.255.255.240
ip access-group CBAC-OUT-NEW in
ip nat outside
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
interface FastEthernet0/1
description INSIDE-TO-LAN
ip address 192.168.100.x 255.255.255.240
ip nat inside
ip inspect CBAC in
ip policy route-map PBR
duplex full
speed 100
interface FastEthernet0/0/0
description CYTA
ip address [public ip 2] 255.255.255.248
ip nat outside
duplex full
speed 100
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 [gateway public ip] track 1
ip route 0.0.0.0 0.0.0.0 [gateway public ip 2] track 2
no ip http server
no ip http secure-server
ip nat inside source route-map CYTA interface FastEthernet0/0/0 overload
ip nat inside source route-map PRIMETEL interface FastEthernet0/0 overload
ip nat inside source static 192.168.100.13 [an ip in the range of public ip 2] route-map CYTA-STATIC-NAT
ip nat inside source static 192.168.3.23 [an ip in the range of public ip 2] route-map CYTA-STATIC-NAT
ip nat inside source static 192.168.100.13 [an ip in the range of public ip] route-map PRIMETEL-STATIC-NAT
ip nat inside source static 192.168.3.23 [an ip in the range of public ip] route-map PRIMETEL-STATIC-NAT
ip access-list extended ALLOW-EVERYWHEREACCESS
permit ip 192.168.0.0 0.0.255.255 any
ip access-list extended ALLOW-WEB
permit tcp 192.168.0.0 0.0.255.255 any eq www
permit tcp 192.168.0.0 0.0.255.255 any eq 443
permit tcp 192.168.0.0 0.0.255.255 any eq smtp
ip access-list extended CBAC-OUT-NEW
permit ip host 192.168.20.1 any
ip access-list extended PBR-NOFILTER
ip access-list extended STATIC-NAT
permit ip host 192.168.100.x any
permit ip host 192.168.3.x any
ip access-list extended WEBFILTERING
permit ip 192.168.101.0 0.0.0.255 any
permit ip 192.168.100.0 0.0.0.255 any
deny tcp any any eq 443
permit ip any any
ip sla 1
icmp-echo [gateway public ip]
timeout 500
frequency 1
ip sla schedule 1 life forever start-time now
ip sla 2
timeout 500
frequency 1
ip sla schedule 2 life forever start-time now
logging 192.168.3.x
snmp-server community key RO
snmp-server location Internet Router 2
snmp-server contact x
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps ds1
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps xgcp
snmp-server enable traps flash insertion removal change
snmp-server enable traps ds3
snmp-server enable traps envmon
snmp-server enable traps icsudsu
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps ds0-busyout
snmp-server enable traps ds1-loopback
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps license
snmp-server enable traps disassociate
snmp-server enable traps deauthenticate
snmp-server enable traps authenticate-fail
snmp-server enable traps dot11-qos
snmp-server enable traps switch-over
snmp-server enable traps rogue-ap
snmp-server enable traps wlan-wep
snmp-server enable traps aaa_server
snmp-server enable traps atm subif
snmp-server enable traps bgp
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps memory bufferpeak
snmp-server enable traps cnpd
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps dial
snmp-server enable traps dsp card-status
snmp-server enable traps dsp oper-state
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps resource-policy
snmp-server enable traps event-manager
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps mpls ldp
snmp-server enable traps mpls traffic-eng
snmp-server enable traps mpls fast-reroute protected
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps ipsla
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps l2tun pseudowire status
snmp-server enable traps vtp
snmp-server enable traps pw vc
snmp-server enable traps firewall serverstatus
snmp-server enable traps ipmobile
snmp-server enable traps rf
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps ccme
snmp-server enable traps srst
snmp-server enable traps mpls vpn
snmp-server enable traps voice
snmp-server enable traps dnis
snmp-server host 192.168.3.x version 2c key
route-map CYTA permit 10
match ip address NATacl-NEW
match interface FastEthernet0/0/0
route-map PRIMETEL permit 10
route-map PBR permit 10
match ip address ALLOW-WEB
set ip next-hop verify-availability [gateway public ip ] 1 track 10
route-map PBR permit 30
match ip address ALLOW-EVERYWHEREACCESS
set ip next-hop verify-availability [gateway public ip 2] 2 track 20
route-map CYTA-STATIC-NAT permit 10
match ip address STATIC-NAT
route-map PRIMETEL-STATIC-NAT permit 10
control-plane
ccm-manager fax protocol cisco
mgcp fax t38 ecm
12-18-2013 09:19 AM
Hi Guys,
I still have isses with the nat translations (i thought it was solved but after a while i see load balancing between providers instead of interested traffic being routed through the desired provider as i wanted to implement using policy base routing)
Nevertheless that i am using PBR as you can see in my configuration at the beggining of this conversation, half of the packets are going through CYTA and the other half through PRIMETEL (for 443,), so i guess PBR is not working as expected.
P.S i've just cleared nat entries and it seems that is working correctly.. i don't know, what to say..Please provide me with commands to test PBR functionality.
