Router 2951 with Multilink ppp
ddevecka
We just fired up a new 2951 with 7-T-1's and the lantency is just horrible. We have called the telco and they say they see no errors, but when we ping and tracert we hot 1000ms to 3000ms to our MPLS network. Also when we hit the multilink serial MPLS connect we see the 1000 to 3000ms leg times. That interface it local to the router. I have copied out config as well.
Any help would be apperciated.
Dan
acampbell
It is my understanding that Interleavining and fragmentation
should only be used on circuits less than 768K.
Try removing
interface Multilink 1
no ppp multilink interleave
no ppp multilink fragment disable
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
acampbell
Try removing
Alex.
Ended up being a bad vwic port, but thaanks for the responce.
