Dual ISP BGP Single Router Slow browshing/ load issue (cisco 2921)
kazimjhon
hello
I have just configured bgp with two isp on a single router and i have 2 public /24 prefixes and i want to route one prefix on isp-1 and the 2nd to isp-2. Now i have three issues
1} no maximum-path command found in my router ( Is it must for this configuration )
2) Browsing issue some websites open and some in  buffering mode
3) Both prefixes Traffic goes isp-1 and when isp-1 down then shifted to isp-2
Below is the router version and configuration
R1#show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M1, REL
EASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sat 25-Oct-14 03:34 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
KhybeNet-R1 uptime is 4 weeks, 4 days, 13 hours, 53 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.154-3.M1.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FTX1803AL6G
3 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO2921/K9 FTX1803AL6G
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc None None None
data datak9 RightToUse datak9
NtwkEss None None None
CollabPro None None None
Building configuration...
Current configuration : 7305 bytes
! Last configuration change at 21:51:55 GMT Mon Aug 15 2022
version 15.4
hostname R1
boot-start-marker
boot-end-marker
no logging console
no logging monitor
aaa new-model
aaa session-id common
clock timezone GMT 5 0
ip domain name
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO2921/K9 sn FTX1803AL6G
license boot module c2900 technology-package datak9
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.1.2 255.255.255.252
description ISP-1
duplex full
speed 1000
no cdp enable
interface GigabitEthernet0/1
description LAN
no ip address
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/1.1
encapsulation dot1Q 100
ip address 103.217.136.1 255.255.255.0
interface GigabitEthernet0/1.2
encapsulation dot1Q 101
interface GigabitEthernet0/1.3
encapsulation dot1Q 102
ip address 103.157.36.1 255.255.255.0
interface GigabitEthernet0/2
description ISP-2
ip address 192.168.2.2 255.255.255.252
shutdown
duplex auto
speed auto
router bgp 135384
bgp log-neighbor-changes
neighbor 192.168.2.1 remote-as 38264
neighbor 192.168.2.1 description BGP With ISP-2
neighbor 192.168.1.1 remote-as 17557
neighbor 192.168.1.1 description BGP With ISP-1
address-family ipv4
network 103.157.36.0 mask 255.255.255.0
network 103.217.136.0 mask 255.255.255.0
network 192.168.2.0 mask 255.255.255.252
network 192.168.1.0 mask 255.255.255.252
neighbor 192.168.2.1 activate
neighbor 192.168.2.1 advertise-map ADVERTISED-ISP2 non-exist-map NON-EXIT-I
SP2
neighbor 192.168.2.1 soft-reconfiguration inbound
neighbor 192.168.2.1 filter-list 1 out
neighbor 192.168.1.1 activate
neighbor 192.168.1.1 advertise-map ADVERTISED-ISP1 non-exist-map NON-EXIT-
ISP1
neighbor 192.168.1.1 soft-reconfiguration inbound
neighbor 192.168.1.1 filter-list 1 out
exit-address-family
ip forward-protocol nd
ip as-path access-list 1 permit ^$
no ip http server
ip http authentication aaa
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 0.0.0.0 0.0.0.0 192.168.2.1
ip route 103.157.36.0 255.255.255.0 Null0
ip route 103.217.136.0 255.255.255.0 Null0
route-map NON-EXIT-ISP1 permit 10
match ip address 30
route-map NON-EXIT-ISP2 permit 10
match ip address 50
route-map ADVERTISED-ISP1 permit 10
match ip address 40
route-map ADVERTISED-ISP2 permit 10
match ip address 20
access-list 20 permit 103.217.136.0 0.0.0.255
access-list 30 permit 192.168.2.0 0.0.0.3
access-list 40 permit 103.157.36.0 0.0.0.255
access-list 50 permit 192.168.1.0 0.0.0.3
balaji.bandi
BGP chooses one best path among the possible equal-cost paths that are learned from one AS. However, you can change the maximum number of parallel equal-cost paths that are allowed. In order to make this change, include the maximum-paths paths command under the BGP configuration.
what happend when you directly connect to ISP Link using Laptop and test  ?
what kind of Link speed from each ISP ?
BB
I have two different isp and 500 mbps each link
Maximum path couldn't found in this version
 Two laptops with different prefix have slow browsing for some sites
Is this laptop test without passing via router ?  have you tested directly connecting to IP ?
BB
directly working fine.
and also shutdown one isp both prefixes working normal .
