Showing results forĀ
Search instead forĀ
Did you mean:Ā
Dual isp configuration
Dea Friends,
I have two offices ,one is branch office and other is head office.Two MPLS link is connected with each other,One link is always back up when other link is goes down .
In running time only one link is working other  as a standby but i want to use both link as bandwith sharing and link sharing.If any one goes down then other should take all the data load and it should sena a email and it's running static routing now.
Please any one have configuration.
Hello.
The solution really depends on routing protocol you use, but all have ECMP feature.
Please provide your network diagram describing the set of routing protocols you use.
