Dual ISP & Dual ASA scenario
nicky0690
Hi All,
  Scenario:-
  i) 2 ISP on 2 different routers.
  ii) 2 ASA (each ASA is connected to each routers directly)
                               ISP1                   ISP2
                              Rtr A                 RtrB
                              ASA 1                ASA 2
                                     SWITCH 1
Requirement:-
i] Load Balancing/Load Sharing between both the ISP's.
ii] Active/Standby between both the ASA
Solution:-
i]  AS path prepending to be used for load sharing by running BGP.
ii] Configuring 2 default routes one for ISP1 and another as back up for ISP2 on ASA.
iii] PBR configuration on RtrA to forward the traffic on RtrB and vice versa.
iv] Stateful Failover on ASA
Kindly do let me know if this is good solution. Also, if there are any  challenges to implement this solution. If anyone has another better  solution please suggest.
Cheers,
Nikhil
Marwan ALshawi
First of all if you use the firewall inactive standby then you will Not be able to use both ISPs
A,so not sure about the pbr how and you use it ?
One more question is the switch configured as layer 2 or 3 ? Can you add another switch as o e switch will be single point of failure here
Also whatbis the default gateway used by hosts is it the Asa or a layer 3 interface in the switch if it's layer 3 ?
The switch will be configured as L3 switch. Yes, the switch will be single point of failure. We are planning to add one more switch to create redundancy.
L3 switch will be DG for the host as Vlans will be created on it.
Cheers,
Nikhil
Ok in this case you will need HSRP on the switches, but HSRP will provide you with active/standby
The ASA in failover mode will be in active/standby as well
If the above is ok with you then just make sure that you align the active hsrp and asa on the same side
If you looking for active active solution then you might use this method
Let's say you two LAN subnets LAN A and LAN B
Configure the hsrp groupnin both switches ton use switch 1 as active LAN A and switch 2 active harp for LAN B
Configure the ASAs to to work individually so each ASA will be working standalone active device
In each switch use static routes with ip sla tracking two static routes with tracking
In switch 1 static route/ default route point to ASA 1 with ip sla tracking to monitor the availability of the ASA1
Second static route point tonthebsecond ASA ip ( assuming you have route to the asa2 via the switch 2) set this static route with higher metric to be used in the case ASA 1 down/ not reachable
This way you can have your network active active and load balanced to some extent
Hope this help
If helpful rate
