dual isp failover issues with cisco 881
I am trying to use dual isp's connections on CISCO 881 by using static route track. I have problem that I can't ping, telnet secondary router IP from WAN(public address,able to ping from router console). This is the reason that secondary connection is not doing fail over when primary fail. SLA all commands are ok and working fine. Its look like issue with nating. only primary route is active and I can ping and telnet from WAN. I want a solution that both addresses are ping able, telnet from WAN, with failover.
Configuration file:
ip dhcp pool phones
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
dns-server 135.196.0.6 xx.196.0.xx 8.8.8.8
interface FastEthernet 3
switchport access vlan 3
int fastethernet 2
switchport access vlan 2
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no shutdown
description "TO LAN"
ip address 192.168.1.254 255.255.255.0
ip nat inside
interface Vlan2
no shut
description "UPLINK TO secondary isp"
ip address 217.33.177.xxx 255.255.255.0
ip nat outside
interface Vlan3
no shutdown
description "UP LINK TO primary isp"
ip address 212.2.29.yyy 255.255.255.248
ip nat outside
ip nat inside source list 100 interface Vlan3 overload
ip nat inside source list 101 interface vlan 2 overload
access-list 100 permit ip any any
access-list 101 permit ip any any
ip route 0.0.0.0 0.0.0.0 212.2.29.yyy track 1
ip route 0.0.0.0 0.0.0.0 217.33.177.xx 10
ip sla 1
icmp-echo 212.2.29.yyy source-interface Vlan3
frequency 5
ip sla schedule 1 life forever start-time now
track 1 ip sla 1 reachability
5 Replies 5
Philip D'Ath
Yep, it is a NAT issue.  You need something more like:
ip nat inside source route-map NAT-VLAN2 interface vlan2 overload
ip nat inside source route-map NAT-VLAN3 interface vlan3 overload
route-map NAT-VLAN2 permit 10
match ip address 100
match interface VLAN2
route-map NAT-VLAN3 permit 10
match interface VLAN3
thanks philips for reply,
Main issue how to do routing among vlans created on switch module. I have two vlans, which dont ping each other when i connect through ethernet cable to vlan1. IP ROUTING, command I cant see running configuration while this is accepted by router. Secondary ISP public IP address don,t let me ping/telnet from Internet while I am able to ping/telnet primary isp public ip. thanks
Please post an updated configuration.
thanks philips,
your suggestion perfectly worked. I have few other issues where phones not registering with PBX using secondary ISP. But just for information, secondary ISP address will not be ping/telnet, till primary goes down. When primary ISP link goes down then I am able to ping/telnet secondary ISP address. When primary link comes up again, if telnet through secondary, router will disconnect and need to telnet again through primary address. thanks for your help.
It would be great if you could mark and rate helpful posts.  :-)
