Dual ISP NAT - Route Specific IP
mustafa.chapal
I have got one LAN behind NAT and two ISP connections. I want to route five prefixes through the First-ISP and the rest traffic through the Second-ISP. I tried configuring route-maps but still unsuccessful. Please view the config below. Help would be appreciated.
interface GigabitEthernet0/0
no ip address
ip flow ingress
duplex auto
speed auto
no cdp enable
no mop enabled
interface GigabitEthernet0/0.10
description LAN
encapsulation dot1Q 10
ip address 192.168.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat enable
ip virtual-reassembly in
ip verify unicast reverse-path
no cdp enable
interface GigabitEthernet0/1
description First-ISP
ip address 1.1.1.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat enable
duplex auto
speed auto
no lldp transmit
no lldp receive
no cdp enable
no mop enabled
interface GigabitEthernet0/2
description Second-ISP
ip address 9.9.9.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat enable
duplex auto
speed auto
no lldp transmit
no lldp receive
no cdp enable
no mop enabled
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat source list 1 interface GigabitEthernet0/1 overload
ip nat source list 1 interface GigabitEthernet0/2 overload
ip route 0.0.0.0 0.0.0.0 1.1.1.1
ip route 0.0.0.0 0.0.0.0 9.9.9.1
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
ip access-list extended external
permit ip any any
ip access-list extended internal
permit ip any 1.1.1.0 0.0.0.255
permit ip any 2.2.2.0 0.0.0.255
permit ip any 3.3.3.0 0.0.0.255
permit ip any 4.4.4.0 0.0.0.255
permit ip any 5.5.5.0 0.0.0.255
route-map 1 permit 10
match ip address internal
set ip next-hop 1.1.1.1
route-map 1 permit 20
match ip address external
set ip next-hop 9.9.9.1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
5 Replies 5
Deepak Kumar
Where is Route-map applied?
You must apply it under the LAN interface as below:
ip policy route-map 1
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi Deepak,
Even after applying the policy route-map, the result is the same that internet is not working.
Mustafa,
As per the configs that you shared, it makes me understand that your Internal LAN subnet is of 192.168.0.0/24 subnet , as you are trying to route your internal lan pool towards First ISP I suggest you to make below corrections in config. Have ip policy route-map 1 statement as it is under interface GigabitEthernet0/0.10 and make below corrections.
no ip access-list extended internal
match ip address 1
Rest of the config leave as it is.
Actually this enable's the first isp to be used by entire 192.168.0.0/24 subnet.
Give it a try and check.
Basically my aim was to route specific networks through the First-ISP and the remaining traffic through the Second-ISP and the following config helped me fix that issue.
Also please help me understand the difference between PBR and how can I make use of it in this situation.
no ip address
ip flow ingress
duplex auto
speed auto
no cdp enable
no mop enabled
description LAN
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat enable
no cdp enable
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat enable
duplex auto
speed auto
no lldp transmit
no lldp receive
no cdp enable
no mop enabled
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat enable
duplex auto
speed auto
no lldp transmit
no lldp receive
no cdp enable
no mop enabled
no ip http server
ip nat source route-map 1 interface GigabitEthernet0/1 overload
ip nat source route-map 2 interface GigabitEthernet0/2 overload
ip route 1.1.1.0 255.255.255.0 1.1.1.1
ip route 2.2.2.0 255.255.255.0 1.1.1.1
ip route 3.3.3.0 255.255.255.0 1.1.1.1
ip route 4.4.4.0 255.255.255.0 1.1.1.1
ip route 5.5.5.0 255.255.255.0 1.1.1.1
ip ssh time-out 60
ip ssh version 2
permit ip any any
permit ip 1.1.1.0 0.0.0.255 any
permit ip 2.2.2.0 0.0.0.255 any
permit ip 3.3.3.0 0.0.0.255 any
permit ip 4.4.4.0 0.0.0.255 any
permit ip 5.5.5.0 0.0.0.255 any
match ip address 1
set interface GigabitEthernet0/1
route-map 2 permit 10
match ip address 1
set interface GigabitEthernet0/2
Currently, you configured NATing with PBR but the post was started with Routing with PBR.
More Information about NATig with PBR :
https://supportforums.cisco.com/t5/network-infrastructure-documents/dual-internet-links-nating-with-pbr-and-ip-sla/ta-p/3126275
Deepak Kumar
Deepak Kumar,
