07-01-2016 08:57 AM - edited 03-05-2019 04:20 AM
Yesterday we had an incident where one of our ISP's had a routing issue yet was still advertising
routes to us that were unreachable.
We have two ASR routers..one dedicated to ISP1 the other dedicated to ISP2
The ASR's are connected to each other via Gig ports..running BGP to each other also
ASR2 -going to ISP2 seems to be the preferred outbound internet route. MY question
is.
Would I simply add an increased weight on the the ASR2 /ISP2 so that outbound internet
routing than chooses ASR1 /ISP1?
ASR1(ISP1)
router bgp 51111
 bgp log-neighbor-changes
 network 50.xx.xx.0 mask 255.255.255.0
 neighbor 10.43.x.2 remote-as 51111--------------ASR2
 neighbor 10.43.x.2 update-source Loopback0
 neighbor 10.43.x.2 next-hop-self
 neighbor 205.x.x.7 remote-as 3111
 neighbor 205.x.x.xx7 route-map Telco_in in
 neighbor 205.x.x.xx7 route-map Telco_out out
ASR2 (ISP2)
router bgp 51111
 network 50.x.x.0 mask 255.255.255.0
 neighbor 10.43.x.1 remote-as 51111--------------ASR1
 neighbor 10.43.x.1 update-source Loopback0
 neighbor 10.43.x.1 next-hop-self
 neighbor 64.x.xx.2 remote-as 41113
 neighbor 64.x.xx.2 route-map ISP_IN in
 neighbor 64.x.xx.2 route-map ISP_OUT out
example--would like network 1.18.126.0 to have ASR1 as best route..ASR2 is advertised as the rout
ASR-1#sh ip route 1.18.126.0
Routing entry for 1.18.126.0/24
 Known via "bgp 51111", distance 200, metric 0
 Tag 4113, type internal
 Last update from 10.3.x.2 1w3d ago
 Routing Descriptor Blocks:
 * 10.3.x.2, from 10.3.x.2, 1w3d ago-----------(ASR2 loopback address)
 Route metric is 0, traffic share count is 1
 AS Hops 3
 Route tag 4113
 MPLS label: none
ASR-1#sh ip bgp 1.18.126.0
BGP routing table entry for 1.18.126.0/24, version 510239969
Paths: (2 available, best #1, table default)
 Not advertised to any peer
 4113 4116 2119
 10.3.x.2 (metric 2) from 10.3.x.2 (10.3.x.2) <--------ASR-2 Loopback
 Origin incomplete, metric 0, localpref 100, valid, internal, best
 219 6119 4116 21199
 65.x.x.17 from 65.x.x.17 (205.x.x.150)
 Origin IGP, metric 8000038, localpref 100, valid, external
 Community: 136979
07-01-2016 11:08 AM
There are multiple was to accomplish this and setting the weight on ASR2 could work, but that would only be known to that router. It might be safer and cleaner to set the local preference for the routes from from ISP1 on ASR1 to a value higher than the default of 100. This attribute will propagate to ASR2 and both of your ASR routers will be on the same page and prefer the routes from ISP1.
Hope this helps.
