05-12-2008 07:34 AM - edited 03-03-2019 09:55 PM
I have a 1812 router configured with 2 different ISP connections. I was able to get a static IP range from both ISPs now and want to configure my router to use OER/SLA to do load-balancing using this example (http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml).
The problem is that I will have inbound traffic on both lines, so I will need to do static mappings for both.
Will the mappings work properly so that if traffic comes into a server on ISP 1, the reply will go back out the same like? Or will I need to set it up so that things are limited to one connection or the other?
05-12-2008 08:22 AM
Worry not, nat mapping will do so that replies will be sent back on the link that are received.
05-12-2008 09:01 AM
That is what I thought, but it isn't working quite right. Currently, my DNS entries point the my DSL, which will be the secondary connection. If I enable the cable/primary connection, I do not receive incoming email. As soon as I shutdown the primary connection, email begins arriving again.
I am attaching the relevant part of my config (only stripped out the vpn parts) with the public IPs changed. Any suggestions or help would be greatly appreciated.
