Dual ISP wan failover with Public IP
Adcom911
We recently had a failover test between between our ISP 1 and ISP 2. The failover portion worked fine via the IP sla's but we were unable to pass traffic through ISP 2. I believe the issue is due to the switch we have the ISP connections coming in on we have the public IP from ISP 1 as the svi between the switch and FTD outside interface. So thus im assuming when we failover to ISP 2 that svi from ISP 1 causes the traffic to be unroutable as ISP 2 is unaware of it.  To solve this would we need a new public IP from ISP 2 to use on vlan 2 and a second outside interface on our FTD? Or is there another way to get this dual wan solution working while keeping vlan 1 public ip in place? Maybe natting between isp 1 and 2?
11 Replies 11
There is no NAT in l3 SW?
MHM
Hello! Currently there is no NAT on the Switch
Ftd do NAT ?
Both ISP know vlan1 subnet?
MHM
FTD does nat and im assuming ISP 2 doesn't know about vlan 1 subnet due to it not working.
You find solution.
ISP2 need to know vlan1 subnet to make retrun back traffic work.
MHM
Gotcha, so dumb question just call ISP2 and say hey can you make a static pointing to that subnet?
Edit: Well they can't point a static since it would direct traffic to a backup port thats not in use....So they just would need to advertise the network on their side possibly?
Correct' this will solved your issue.
MHM
Thank you! I will reach out to ISP 2 and see if thats possible.
Hello
I would say make that switch a L2 transit switch, and relocate both of your ISP PIPs on to the FW, from there you can LB across both ISPs with NAT redundancy, no need to call any ISP for additional allocation, in fact you will have a spare 150.x.x.x. to play with.
Kind Regards
Paul
I kind of like that solution. How would you do NAT redundancy? I'm not familiar with that technique
Hello
That would depend on the make/model of the FWs tbh..  the above design would be applicable though in fact we have a couple of customers running similar on Palo Altos.
Example
dual FWs in Active/passive or active/active modes, sharing the ISPs addressing, this should will allow high availability so to utilise both wan circuits at the same time (if required) if you do also want to use a wan transit switch just need to be aware that could be a single point of failure unless you have a stack.
Kind Regards
Paul
