Dual MPLS BGP EIGRP Design Validation, Please suggest..
vishal_sh
Hi Friends,
Need your inputs on attached two design options. Which one is better and is there any kind of issue with second scenario (Diag2)?
We have basically multiple sites which will connect to two MPLS service providers in any to any communication.
EBGP between CE and PE Routers with both Service Providers. IBGP between CE1 and CE2 Router on a back to back physical link.
EIGRP as internal routing protocol. Redistribution will be configured between BGP to EIGRP.
Load sharing will be done on both providers using AS path preprending and Local Preference.
Tagging and Route-maps will be used while redistibuting from BGP to EIGRP to stop propagation of these routes again to BGP cloud.
AS path access-list allowing only local AS routes to BGP (Do I still need this if I am using tags in BGP - EIGRP Redist.?
Do you see any issues in this design?
Are we following current best practices?
Out of the two options for connecting Core Switches with WAN Routers, I will need additional module on Routers with the first option, Second option also looks redundant and utilizing only three interfaces on Routers. Do you see any potential issue with second option (Diag2)?
Looking for your valuable suggestions..
Giuseppe Larosa
Hello Vishal,
there are some notes that may be useful about your design and the different topology options.
We see that design option 1 has the cross -over direct links between WAN router CEi and Core switch j with i <> j, design 2 misses this cross-over direct links.
Design option 1 provides link redundancy in the EIGRP routing domain and fault tolerance to single link fault for these addtional links.
Design option 2 can be improved if EIGRP is activated on the CE1 to CE2 direct link. If this is done the EIGRP domain achieves redundancy and fault tolerance to single link fault. So this is the first suggestion.
Looking at the whole routing plane we can see that design option 1 has still an advantage over design option 2: it allows true load balancing from the point of view of a single core switch in reaching the remote site IP subnets. It is enough that the two CE routers redistribute BGP routes into EIGRP with the same seed metric to achieve. Until both CE routers advertise the same IP subnet with the same seed metric each core router sees two equal cost paths one via CE1 and MPLS SP1 and one via CE2 and  MPLS SP2.
This load balancing over both MPLS clouds cannot be achieved by design option 2 even with EIGRP enabled on CE-toCE link as each core router will prefer the directly connected CE router for the way EIGRP metric works also for external EIGRP routes.
In order to achieve load balancing over both MPLS clouds the core switch should support GLBP on client facing Vlans. This would lead to some clients using core switch 1 as default gateway and other to use core switch2.
GLBP may be supported or not on the core switch multilayer switches.
So if the design objective is to use both MPLS clouds in load sharing and GLBP cannot be used, design option 1 is to be preferred, but the direct link CE to CE might be removed under certain conditions.
More on this later.
Let's see if the complexity of the solution in the routing plane can be reduced.
Redistribution of BGP into EIGRP is needed unless a full mesh iBGP is built between CE1, CE2, core switch1, core switch2. So we consider this a needed part.
My understanding from your notes is that you are performing mutual redistribution, that is you are also redistributing EIGRP into BGP.
If the number of EIGRP routes is not high < 200 EIGRP routes can be injected in BGP by simply using the network command under router bgp and this is a great simplification as it removes the need for mutual redistribution.
So the second suggestion is to consider the use of the BGP network command instead of redistribution of EIGRP into BGP in the smaller sites that have not so many local routes.
The last point to discuss is the role of the iBGP session between CE routers.
Each CE router connects to a different MPLS SP cloud. If all sites are multihomed to both MPLS SP1 and MPLS SP2 different strategies are possible:
a) total separation between the two clouds-
the iBGP session is not needed at all in this case each SP cloud is stand alone if one remote site link to SP1 fails the remote site IP subnets will be reachable via SP2 and CE1 will stop to inject the routes into EIGRP in the local site.
The design is still fault tolerant to a single link or node fault, load balancing may be performed in normal conditions.
This is a good choice for remote sites.
b) interconnection between the two VPNs in central site and/or selected sites-
In this case the iBGP session provides a backup path via SP2 to those remote sites that are only connected to SP1.
The event that can be covered with this design is site K only connected to SP1 to be able to communicate to site M only connected to SP2. This is a double fault that might happen.
The iBGP session on central site and/or remote site can cover this case by propagating routes between SP1 and SP2 via the CE routers of central site /selected sites.
So in my opinion the iBGP session is useful only when you want to implement strategy b).
And this leads again to the fact the direct link between CE routers may be removed saving the addition of a network module.
Until you have the iBGP session if you want to keep the two clouds separated (strategy a) you need the AS path filtering, because the iBGP session provides the leakage on the routing plane between SP1 and SP2 clouds.
The route-maps with tags applies only to redistribution of EIGRP into BGP and does not provide filtering on BGP routes passed to an eBGP peer
The AS path filtering should be removed or modified to allow route propagation between SP1 and SP2 clouds.
However, if the choice is this one (strategy b) it can be implemented only on central site or selected sites is not needed in all sites to save on complexity.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Vishal,
More on this later.
Hope to help
Giuseppe
Thanks a ton Giuseppe!
These were the things I wanted to discuss and your inputs are well thought, very helpful.
Load Balancing on both Service Providers is not an objective at the moment but yes load sharing will be done. But I like the idea to propose Option 1 if load balancing is ever required..
b) Though Interconnection between the two VPNs via some central site. Yes, I know we can run into this situation and therefore would like to keep this IBGP link between two CEs. Further, Do you suggest to run EIGRP as well on same link between routers to have complete rectangle form of EIGRP running if Option 2 is taken (No Cross)?
And I will surely consider your suggestion of using network command in bgp instead of redistributing eigrp. This was on my mind, but you recommending it has strengthened that thought. One question regarding this, Can we summarize some subnets via network command when possible or it has to be exactly same as in IGP (subnet and mask)?
Will keep Route-maps (tags) and AS path access-list to avoid Routing loops and transit AS scenarios. One of the friend suggested that using community will be better and both of these(Tag, As path acl) will not be required. Haven't not tried or simulated it yet.. any experience?
I want to introduce default routes to all remote sites towards two major sites for Internet traffic. Any best practices?
Thanks a lot again for your time and inputs..
This is a very interesting thread!
Giuseppe, a couple of things:
  • You mentioned the iBGP peering between the CE routers would be to allow a site to be used as a transit AS. Even if the iBGP peering wasn't there, wouldn't it be used as a transit through BGP (SP1) -> EIGRP -> BGP (SP2)?
  • Let's say we didn't want to load balance between SP1 and SP2. And we wanted to be able to control what traffic goes through each link. Couldn't the iBGP be used to influence the route selection more specifically?
Thanks in advance!
