Dual NATting for 2 ISP Link
I have two ISP link
                    |--------------------------ISP 1
LAN--- Router
                    |--------------------------ISP 2
I have configured IP SLA and both links are active active right now.
If i have a server 10.1.1.100 which is natted to ISP 1 IP pool and if the ISP 1 link goes down it should get NATTed to ISP 2 IP Pool and work. But its not working I have tried all the methods. Can some1 please help me to troubleshoot or configure this..
Please find the configuration of NAT
ip sla monitor 1
type echo protocol ipIcmpEcho XX.XX.XX.XX
threshold 3
frequency 5
ip sla monitor schedule 1 life forever start-time now
ip sla monitor 2
type echo protocol ipIcmpEcho YY.YY.YY.YY
threshold 3
frequency 5
ip sla monitor schedule 2 life forever start-time now
track 101 rtr 1 reachability
track 102 rtr 2 reachability
interface FastEthernet0/0.800
encapsulation dot1Q 800
ip address XX.XX.XX.XX 255.255.255.248
no ip redirects
no ip unreachables
ip accounting output-packets
ip nat outside
ip virtual-reassembly
no ip route-cache same-interface
no ip route-cache
ip tcp adjust-mss 1420
no cdp enable
interface FastEthernet0/1
ip address YY.YY.YY.YY 255.255.255.248
ip nat outside
no ip route-cache cef
no ip route-cache
interface FastEthernet1/0
ip address zz.zz.zz.zz 255.255.255.240
ip nat inside
ip policy route-map ISP
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 xx.xx.xx.xx(NH) track 101
ip route 0.0.0.0 0.0.0.0 yy.yy.yy.yy(NH) track 102
ip access-list standard ISP1
permit 10.1.1.100
route-map ISP permit 10
match ip address ISP1
set ip next-hop verify-availability xx.xx.xx.xx(NH) 10 track 101
set ip next-hop verify-availability yy.yy.yy.yy(NH) 20 track 101
ip nat inside source static 10.1.1.100 xx.xx.xx.x1 route-map ISP1 extendable
ip nat inside source static 10.1.1.100 yy.yy.yy.y1 route-map ISP2 extendable
route-map ISP2 permit 10
set ip next-hop verify-availability yy.yy.yy.yy(NH) 10 track 102
route-map ISP1 permit 10
Please help...
Nitesh
Latchum Naidu
Hi Nitesh,
Please refer the below config may help you.
This is what I have at one of my customer router and working as expected.
Description Primary link ISP1
ip address 12.x.x.x 255.255.255.240
ip nat outside
Description Secondary link ISP2
ip address 76.x.x.x. 255.255.255.0
ip nat outside
interface FastEthernet1/1
Description Inside LAN segment
ip address 172.168.60.1 255.255.255.0
ip nat inside
access-list 100 permit ip 172.168.60.0 0.0.0.255 any
route-map isp1 permit 10
match ip address 100
match interface FastEthernet0/0
route-map isp2 permit 10
match interface FastEthernet1/0
ip nat inside source route-map isp1 interface FastEthernet0/0 overload
ip nat inside source route-map isp2 interface FastEthernet1/0 overload
ip route 0.0.0.0 0.0.0.0 12.y.y.y -----> Primary Default route pointing towards Next hop ip of ISP1
ip route 0.0.0.0 0.0.0.0 76.y.y.y 10 -----> Backup Default route with higher AD (10) pointing towards Next hop ip of ISP2
the above example shows how we can perform Failover for PAT (Port Address Translation) for the traffic going out to Internet. By using route-maps and "match interface" option, we can achieve failover for Static NAT translation as well which is generally configured when services are hosted out to the internet like webserver or exchange server hosted inside accessible from Internet
route-map isp1static permit 10
route-map isp2static permit 10
ip nat inside source static 172.168.60.2 12.x.x.x route-map isp1static
ip nat inside source static 172.168.60.2 76.x.x.x route-map isp2static
Please rate all the helpfull posts.
Naidu.
