dual pppoe sessions
evahenshaw
                   I'm trying to set up dual pppoe sessions on a router through sub-interfaces.  Unfortunately the router is connected to a high speed data terminal that has two channel cards but they are both on the same subnet and cannot be changed.  Is there any way I can set up two pppoe sessions that can run at the same time with the path to the same subnet?  For example:  router connected to the data terminal which is connected to an antenna for satellite connection.  Want to set up two pppoe sessions, one for video and one for internet browsing (different costs).  Any suggestions?
Eva
paolo bevilacqua
PPPoE client is not supported on sub-interfaces. You will need multiple physical WAN interfaces.
