Dual SIM Configuration and Failover
abc1235
Hallo,
I have a C1126-8PLTEP ISR router with DUAL SIM capabilities. I would like to configure it such that I when the primary SIM fails, the secondary takes over. What is interesting is that I have created a controller profile for the primary interface but I can't do the same for the secondary cell interface, despite it being available. This is the error message I receive:
R1(config)#controller cellular 0/2/1
Can't find controller Cellular 0/2/1 ^
% Invalid input detected at '^' marker.
The 2 cellular interfaces are shown:
Cellular0/2/0 10.139.223.61 YES IPCP up up
Cellular0/2/1 unassigned YES NVRAM down down
Lastly, why can't I see the controller Cellular 0/2/0 configs in the running config?
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
Thanks in advance.
Mark Elsen
 -  Check current software version, use latest and or advisory release , check if that can help.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
5 Replies 5
Mark Elsen
 - What command completion options do you have when you type : controller cellular ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
abc1235
Hallo @Mark Elsen Here is the output
R1(config)#controller cellular ?
<0-0> Controller slot number
R1(config)#controller cellular 0/?
<0-5> Port Adapter number
R1(config)#controller cellular 0/2?
R1(config)#controller cellular 0/2/?
<0-1> Port number
R1(config)#
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
 Make sure you attend this requirements:
"This feature is supported on Global, Australia, Canada, and AT&T SKUs. This feature is not supported
on Sprint and Verizon SKUs."
https://gluhcdn.azureedge.net/mti/productmanuals/1019557_0.pdf
abc1235
Thanks @Mark Elsen. That was actually the problem. An IOS upgrade is required. Thanks again
